First IDIT, Seconds IDI - Got Questions
Old Jul 29, 2013 | 04:11 PM
El Camino Man's Avatar
El Camino Man
Hey guys. This is my 2nd IDI and I still like em! This one sports the factory turbo. I gotta say, still not impressed with power... My old IDI was a poor performer and this one is... "ok". Being a crew cab don't help either.
I know im probably beating a dead horse on this one but: Im wanting to crank a few more ponies out of this baby. I know on the old IDIs, you cut off the fishbowl and put on a better muffler... that's about it unless you added a turbo. Iv heard of cranking up the IP but that could be disastrous on a non-turbo application, so can I bottom it out on this IDIT? Or do I need to be careful still?
Also, I happen to have a tore-up Powerstroke sitting in the garage. Would swapping out turbos be an upgrade? Or is it too much work for the gain?
Any other info is appreciated!
Old Jul 29, 2013 | 04:34 PM
Forddiesel17's Avatar
Forddiesel17
If it is a factory turbo get rid of the crushed down pipe. Check your timing and depending on how many miles ip and injectors may need to be replaced to freshen things up a bit. If you want to add fuel you need a pyrometer to check egts.
Old Jul 29, 2013 | 05:26 PM
IDIDieselJohn's Avatar
IDIDieselJohn
X2 ^^^
And looks like your under the IDI spell now. It's all downhill from here, soon you'll have a yard full of these things
Old Jul 29, 2013 | 05:55 PM
Bonanza35's Avatar
Bonanza35
Isn't a 97 an early psd? If so it is easy to make power.
Old Jul 29, 2013 | 06:40 PM
El Camino Man
Wrong truck lol. It's not in my sig. It's a 94 with 147k
Old Jul 29, 2013 | 07:34 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
just put the psd in the idi truck and call it a day.........
Old Jul 29, 2013 | 08:49 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
these are all old school mechanical engines with injection pumps and injectors being medium ware items.
this means there is no auto tuning as you know.so you have to keep the ip injectors fresh,and timing set manually from time to time.
the problem is,tuning up an idi today,means spending about the same to just replace a whole idi diesel engine so most don't do it.especially considering,they'll still run like a wounded low hp dog for years anyway.
it's getting to be just cheaper in some cases to just start with buying a 94-97 psd truck.many of those going for low bucks now.by low bucks i mean lower than buying a idi truck that needs a tune up and resolving all the oil and fuel leaks lol.
if you've got a good idi diesel truck that's worth the grand to freshen up and time,then go at it.they're still worth it.
Old Jul 29, 2013 | 09:38 PM
El Camino Man
The PSD is tore-up lol i.e. scored piston
So the psd turbo is a no go?
Old Jul 29, 2013 | 09:46 PM
kla94's Avatar
kla94
If you get rid of the crushed down pipe, as stated, put a good reman ip and reman injectors, time it in right, then you will be happy with the results. I put a 3" exhaust elbow and 3" down pipe into a 4" straight exhaust. Made a difference. I'm pushing 80ccs of fuel. That made a big difference.
Old Jul 29, 2013 | 10:26 PM
Red454sedgwick's Avatar
Red454sedgwick
I've got my self talked in to trying to put a psd trubo on to my idi, but I think I'm going to find a second gernation trubo, there is more aftermarket support for them. and the bolts are on the top of the turbo. There are a couple threads on it.
I just put my idit back together with a new gasket kit, it seemed to help, I was hauling half a load of cows today at 80mph, before I could only do about 70
Old Jul 30, 2013 | 12:34 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Pyro, max the fuel, crank the wastegate. From there, or before, put a good free flowing exhaust on there, if you cant do the elbow upgrade at least do the downpipe. Get it timed after turning up the fuel. If everything is in good shape that should net you 200whp give or take a few.
Old Jul 30, 2013 | 08:56 PM
KrautBurner's Avatar
KrautBurner
I too just picked up a 1994 IDIT F350 Crew Cab
mine's a Dually with a 5 speed
so far I'm pretty happy with her (replaced my 1977 F250 SuperCab with the 460/C6)
Old Jul 30, 2013 | 09:22 PM
kla94's Avatar
kla94
Nice to see you here. Spoke to you on
another forum. Nice truck!
Old Jul 30, 2013 | 09:33 PM
KrautBurner
thanks
I didn't intend to ThreadJack
so I posted my own intro thread in the forum https://www.ford-trucks.com/forums/1...t-a-turbo.html
Old Jul 30, 2013 | 09:38 PM
KrautBurner
like this one? http://www.summitracing.com/parts/gbe-52103
94-97 Downpipe Install - TheDieselGarage.com
