Sean: can't give you offset until I measure it. Minimum diameter was 17" starting in '05 MY due to brake rotor size and factory went up to 20". I believe all were 8" wide.
I'm not sure it seems most tires on these trucks are 265 /285 75 r16 as long as the tire doesent rub the inter wheel well. Not sure right out of the gate stock, it seems like the tires were a little lower
Like Scott said, 05+ had the bigger brakes and used 17", 18", or 20" wheels and they were all 8" wide with an 8x170 bolt pattern. Offset varies from 38 to 44 depending on what wheel it was. Your truck with a leveling kit could probably pull off a less aggressive setup than mine but when you have a lifted truck with stock offset and backspacing it makes the wheels look really sunk into the wheel wells. Also, the factory 8" wide wheel will limit how wide of a tire you can run. My 4.5" Rough Country lift suggested a 17x8 wheel with 0 offset and 4" of backspacing with a 35x12.5x17 tire. I just opted for a little more poke and a bigger wheel.
I don't even know if I would like the 20"
I am not into the tiny rubber band look on the wheels.
I also am not going to get bigger tires mine size wise are just fine
I think the 20's on the stock tire size looks good, but when you're doing a meaty tire I think the 18's look better, not to mention they are quite a bit cheaper.
