engine sawp, throttle cable question
Old Jul 28, 2013 | 12:36 PM
dixiestripes351's Avatar
dixiestripes351
I am in the prosses of swaping out my 300 l6 for a high performance 5.8 that I am building for my 95 f-150 4x4. I am going carbureted. the question is can the stock throttle cable be utilized, or will I have to buy a different cable assembly? thanks
Old Jul 28, 2013 | 04:38 PM
kermmydog's Avatar
kermmydog
I would say if you have a single cable & the end of the cable has the same connection as your running on the I-6 your fine. But you will have to decide once you get the engine in will it be to short.
Unless some has done exactly what your doing everything will be a guess. The other option is look up a throttle cable for a 95 with an I-6 & one for a 5.8.
Craig
Old Jul 29, 2013 | 02:44 PM
Ranger80's Avatar
Ranger80
You may get lucky and be able to route the cable in a way that it will work. On EFI vehicles, the cables are longer to reach the throttle body, as well as the older I6's to reach the carb on the passenger side of the engine. You may end up having to get a new/used cable for a carbureted V8.
Old Jul 30, 2013 | 05:14 PM
dixiestripes351
ya I figured its gunna be a piece it together as u go swapping engines. was seeing if anyone els was been thu it.
monkey jason
Feb 9, 2014 01:55 PM
damarble
1997 - 2003 F150
Jan 23, 2014 03:40 PM
algorythm
May 26, 2007 06:31 PM
6T6Shorty
Mar 13, 2007 01:11 PM
drive_old_ride_new
Jun 2, 2004 02:40 PM
