Changing ignition coils
Old Jul 28, 2013 | 06:40 AM
gunyr310's Avatar
gunyr310
I have a bad ignition coil on a 2006 f150 5.4trition. How do I go about changing it out? Most of my mechanic skills have been learned off of youtube and I can't seem to find anything about this. Thanks for your help.
Old Jul 28, 2013 | 10:46 AM
dakotarider's Avatar
dakotarider
Pretty simple actually, unpluge the wire on it by depressing the little tab, unscrew the small bolt which is about 8mm or so then pull up on the coil pack. When putting on the new one, use some di-electric grease in the end of the boot to prevent it from sticking to the plug. If you try to find a you tube video about spark plug removal, you will probably see teh coil pack be ing removed.
darcrysd
Sep 1, 2014 09:44 PM
scottblogs
Apr 24, 2014 10:24 AM
pminne
Jun 4, 2009 10:41 AM
eigenvector
1983 - 2012 Ranger & B-Series
Aug 26, 2006 08:35 AM
rodhuffaker
Mar 1, 2004 05:03 PM
