Low fuel pressure
Old Jul 27, 2013 | 08:49 AM
BigRed7.3l's Avatar
BigRed7.3l
Low fuel pressure
So I just installed the the gauge pod on my truck and
i've noticed my fuel pressure is at like 25 when coasting but as soon as i hit that throttle it drops to zero
My fuel filter is only a few months old and the pressure sending unit isnt leaking any fuel so i'm kinda stumped. No real loss of power either. Really hoping it isn't a pump.
And I should add it has a Check Engine light but no codes.
Any ideas? Thanks
Old Jul 27, 2013 | 09:27 AM
JOHN2001's Avatar
JOHN2001
Just to verify the screens in your tank are clogged. Take you gas cap off. Disconnect the fuel line from the back of the fuel pump and blow air back into you tank using compressed air. If you hear a big bluuurrrrpppp you need to drop the tank and do the hutch mod
Check fuel pressure again after doing that and let us know.
Old Jul 27, 2013 | 09:29 AM
BigRed7.3l's Avatar
BigRed7.3l
Thanks a lot.
gonna take me a little bit to get to that but once i do ill let you know
Old Jul 27, 2013 | 09:35 AM
JOHN2001's Avatar
JOHN2001
Also which port did you put the sensor in on the fuel bowl? There's two.
http://www.guzzle7pt3.com/hutch.php
While your there you may as well do this one too
http://www.guzzle7pt3.com/harpoon.php
Old Jul 27, 2013 | 09:36 AM
BigRed7.3l's Avatar
BigRed7.3l
the one on the back of the fuel bowl, towards the cab.
Old Jul 27, 2013 | 09:47 AM
JOHN2001's Avatar
JOHN2001
There are two of them back there. You want to have it in the one closest to the passenger side
Old Jul 27, 2013 | 10:07 AM
BigRed7.3l's Avatar
BigRed7.3l
ahhh i didnt even notice that one there, i used the drivers side
Old Jul 27, 2013 | 10:15 AM
JOHN2001's Avatar
JOHN2001
That's fine for now to get you the information you now know. I would move it whenever you get time. For now just blow air back into the tank and let's see what changes. Cycle the key a few times before you try to fire it up. Let the pump get some fuel back in the line you blow out.
Old Jul 27, 2013 | 10:54 AM
Tugly's Avatar
Tugly
Minimum fuel pressure is 45 PSI, 50 PSI - 65 PSI is the full range I see with all my mods.
Old Jul 27, 2013 | 12:04 PM
BigRed7.3l's Avatar
BigRed7.3l
ok i did that and now my truck is running extremely rough even when i put it back the way it was....
I should have never touched it
Old Jul 27, 2013 | 12:15 PM
JOHN2001's Avatar
JOHN2001
You should not have done anything to hurt anything. What I'm guessing is you jay have a lot of air in your fuel lines now. Try letting it run for a little while
Old Jul 27, 2013 | 12:21 PM
BigRed7.3l's Avatar
BigRed7.3l
Yeah that's what I was thinking. Ill let her run for a bit see what happens.
Old Jul 27, 2013 | 12:33 PM
BigRed7.3l's Avatar
BigRed7.3l
Yup must have had a ton of air because it took about 15 mins on Hi-idle and now it's fine lol.
Ill hit the line with a compressor once I get my compressor back.
Ill keep in touch. Thanks a lot guys
Old Jul 27, 2013 | 01:54 PM
dn29626's Avatar
dn29626
If the tank and screens prove to not be the reason for low pressure, disassemble the FPR and check for damage (broken spring, stuck part, collapsed spring support).
Shawn Paris
Aug 2, 2016 10:56 PM
gtclone
May 4, 2015 06:12 AM
landmobile
Mar 16, 2012 10:20 PM
88f1504x4
Nov 27, 2011 02:11 AM
Trapping
Apr 26, 2011 08:04 PM
