Input on engine selection.
Old Jul 27, 2013 | 05:45 AM
topmoo's Avatar
topmoo
Ax, this looks like a real EFI to me, but I am Not an expert:
The Edelbrock Pro-Flo² EFI System is the second generation version of Pro-Flo electronic fuel injection systems. This system has been upgraded with new powerful electronics featuring full-sequential injection and all the components you need to convert a carbureted engine to EFI.
For non-emissions applications, each system includes:
Intake manifold with fuel injectors, fuel rails, and throttle body
Wiring harness
Engine control unit (ECU)
Narrowband O2 sensor
Handheld calibration module
Installation hardware
Pro-Flo² software
Flash-Programmable ECU
Engineered by EFI Technology, a world leader in advanced electronic engine management, this control unit features flash-programmable memory and full-sequential injection (individual injector firing). Flash memory allows multiple tuning options, including Map-N (Speed Density) and Alpha-N (Speed Throttle). Map-N references RPM (engine speed) against MAP (manifold absolute pressure) to determine fuel and spark requirements; Alpha-N references RPM against throttle position. A base calibration is preloaded, and base calibrations for common performance engines are on the included CD. Use Pro-Flo² software to create custom calibrations. Closed loop fuel targets with included narrowband or optional wideband O2 controller are also supported.
Handheld Calibration Module
Edelbrock pioneered tuning on-the-fly FI with the original Pro-Flo that featured an exclusive handheld calibration module. Also included with Pro-Flo², this unique module plugs into the ECU for fast access anytime. Save up to three calibrations. An easy-to-read display allows real-time adjustments without a computer. Initial calibration, however, must be loaded with Pro-Flo² software on a laptop or PC.
Pro-Flo² Software
If laptop tuning is preferred, use Pro-Flo² software to tune, save, and restore unlimited custom calibrations. Use ''I-link'' to connect online to Edelbrock Tech Support.
It is expensive, but might save money in the long run.
Old Jul 27, 2013 | 09:39 AM
AXracer's Avatar
AXracer
Topm,
What it is lacking is individual cylinder ignition control i.e. coil packs. it still uses a mechanical distributor. Some modern engines have other efficiency features like variable valve timing, direct cylinder fuel injection, etc. The engine in my truck can shut off 2 or 4 cylinders when not needed.
Old Jul 27, 2013 | 09:52 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by 51dueller
...Me personally and I'm a big Ford guy, I wouldn't even touch a 4.6/5.4L. ....
Glad to hear I'm not the only one.
Originally Posted by AXracer
Topm,
You view that as a disadvantage (I can understand why) but to me that means instead of 8 @ $30-$50 coilpaks, you have just one, plus a distributor that rarely causes problems with wear parts that cost $30 to replace. I have that exact situation with my DD, it has a distributor with rotor and one coil, plus MAF MPFI. It is 27 years old now and still has the original rotor and cap.
I don't know how it is with Fords, but for any GM LT/LS motor, they sell a "marine" or stand-alone controller that is a plug-in to the engine harness, eliminates all the extraneous crap like passkey, airbags, and transmission interlocks (if you want to).
Old Jul 30, 2013 | 07:50 PM
Oxfordrider's Avatar
Oxfordrider
I have located a 1987 F150 with a carbureted 351W with around 88,000 miles. Engine runs well according to seller. I should be able to pick it up for under $300. This seems like a good solution. Any advice?
2muchgrass
Mar 28, 2013 11:20 AM
86stepsideF150
Feb 14, 2009 04:00 PM
lariat87
32
Jan 26, 2007 05:57 PM
indian_outlaw87
Engine Swaps
Jan 31, 2005 09:53 AM
Danos-f150
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 19, 2004 12:37 AM
