93 idi no start
Old Jul 26, 2013 | 01:57 PM
subs1000w's Avatar
subs1000w
93 idi no start
ok so i got this truck not to long ago and its been fine but about a week ago i was driving and lost power/fuel for a few seconds, but then it kicked back on and had been fine till yesterday, when it died again, this time havent gotten it to run since, also right before it died noticed it "missing" at idle while at a light but still had good power under load
i have replaced fuel filter and tested lift pump and got good flow, and i get a click from the feul solinoid, where do i go from here
Old Jul 26, 2013 | 04:11 PM
Perk85F250's Avatar
Perk85F250
Loosen a couple of injector lines, crank the engine over. You should see fuel squirting out. You may have a small amount of air in the system due to the filter change. Cranking the engine with the injector lines open will purge it out. If you don't get fuel to the injectors, I would suspect the injector pump is bad. Maybe others here can give you more advice.
aje1535
22
Oct 1, 2016 06:56 AM
Sparkplugless
Sep 21, 2012 07:42 PM
jt46321
Dec 17, 2009 05:34 PM
big bad bob
Jan 22, 2007 10:25 PM
otter712
May 14, 2004 09:37 AM
