Romeo or windsor
Old 07-25-2013, 11:15 PM
foreverfordtrucks's Avatar
foreverfordtrucks
foreverfordtrucks is offline
Romeo or windsor
How do you tell if your 97 f150 4.6 is a Romeo or windsor? Someone told me that if your 8th digit of your vin is a 6 it's a windsor and if its a w it's a Romeo , does this sound rite?
Old 07-25-2013, 11:46 PM
Cubawashere's Avatar
Cubawashere
Cubawashere is offline
Apparently that would be the case according to this other thread:
https://www.ford-trucks.com/forums/8...in-number.html
Old 07-25-2013, 11:51 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
You got it right.
GOOD LUCK.
Old 07-28-2013, 11:50 AM
bobiker's Avatar
bobiker
bobiker is offline
what is this post about????
Old 07-28-2013, 11:00 PM
Cubawashere
The post is about how to tell the differences of some motors that are same size but made at different plants such as the 4.6ltr. Here are a few of the differences:
REP (Romeo Engine Plant) motors have 11 bolts on the left valve cover, WEP (Windsor Engine Plant) motors have 13.
Camshafts sprockets are retained differently between the two and the TDC camshaft alignments are different.
Water pump hose under the intake manifold is retained differently, REP is clamp, WEP is metal tube and nut.
REP Crankshaft main caps have 2 main cap bolts, 2 jack screws, 2 side bolts. WEP crank main caps have bolts, dowel pins, but no jackscrews.
Number of thrust washers on the last crank journal are different.
Crank main cap torque specs are different.
Old 07-30-2013, 06:25 PM
bobiker's Avatar
bobiker
bobiker is offline
Thanks man very interesting good info to know my wifes is a 01 f150 5.4L. So there would be differences for this motor to.
Old 08-01-2013, 05:42 PM
blupupher's Avatar
blupupher
blupupher is offline
No, 5.4's for trucks were only built in Windsor.
The 4.6 is the one that can be either.
Old 08-02-2013, 06:03 AM
Georgeandkira's Avatar
Georgeandkira
Georgeandkira is offline
the aluminum version
Hello, I heard that Ford makes the engines (either the 4.6 or 5.4 or both) out of aluminum for Lincoln and Mustang cars. Which plant makes those? Kira
tomsolie
Modular V8 (4.6L, 5.4L)
56
03-29-2024 11:35 AM
z 97ford1
02-05-2010 06:06 AM
Freak4Ford
1997-2006 Expedition & Navigator
08-25-2005 09:18 PM
pbsterling
1997 - 2003 F150
06-06-2004 01:51 PM
hickmysta
02-18-2004 09:02 AM
Quick Reply: Romeo or windsor
