long crank
Old Jul 24, 2013 | 04:58 PM
alexisvfd's Avatar
alexisvfd
long crank
I have a 04 6.0 and I added gauges to it a while back and my oil guage is leaking...it is causing it to take a while to crank I beleave because its loosing oil pressure...I have the sensor for my guage where my oil sensor...coming out of the block with a tee and the sensor coming out the side and my original sensor on the top..but what I found out was that the threads for everything ain t the same and I cant find the fitting..everythings good but the original sensor has different threads like a fine fine thread...anybody had this problem
Old Jul 24, 2013 | 05:48 PM
dannyboy950's Avatar
dannyboy950
If you are talking about where the originol dash gauge sending unit was that is some kind of metric thread almost a jic by the pitch. Never have found anything that will fit in there corretly without some small leak.
Old Jul 24, 2013 | 07:22 PM
alexisvfd's Avatar
alexisvfd
that's it..its really fine thread...is there another place to put it then so I can put the original sensor back in
Old Jul 24, 2013 | 07:47 PM
dannyboy950
You can use the actual test port on the bottom front of the filter houseing sometimes has a quick disconnect fitting kind of like a stablock or fuel quick disconnect on a detroit 71 series. A 12mm thread if i remember right. available in a adapter from most hydraulic supply shops. They make an adapter from metric to NPT thread. About $12. ot ya can order the adapters from FORD $$$$$
Old Jul 24, 2013 | 08:16 PM
cheezit's Avatar
cheezit
iirc its called a storm fitting
Old Jul 25, 2013 | 07:12 AM
npccpartsman's Avatar
npccpartsman
The stock oil sending unit is 7/16-20 bolt thread. That's why it's almost impossible to find anything to go in the hole without retapping to something different.
Old Jul 28, 2013 | 07:46 PM
alexisvfd's Avatar
alexisvfd
npccpartsman r u talking about where I am where the original sensor is
ddetrick78
Dec 12, 2012 08:42 PM
04mudslinger
1997 - 2003 F150
Feb 25, 2010 07:41 AM
StrokeThis96
Jan 13, 2008 07:26 AM
Avanti
Bronco II
Jun 12, 2004 07:34 PM
jcs1966
Nov 21, 2003 05:36 AM
