Good leveling kit or method??????????
Old Jul 23, 2013 | 09:03 PM
4mr11C20's Avatar
4mr11C20
I have a 1992 F150 extended cab running 32 x 11.50 on a stock lift. Like most Ford trucks it sits nose down. My tires rub when turned to the extreme. What is the best way to get that nose up in the air? I want to do a four inch lift eventually but my budget right now is only going to allow for a leveling kit or less expensive solution. Thanks
Old Jul 23, 2013 | 11:02 PM
Encho's Avatar
Encho
The Southernmost Mod
New front springs should be a viable solution on a budget, Moog apparently makes the best ones... though I can't remember the model, can anybody else please share it?.
Old Jul 23, 2013 | 11:30 PM
RIKIL's Avatar
RIKIL
I have the same truck but not extended cab.
http://www.imgur.com/aAK9L15.jpeg
Do the tires rub on the edge of your bumper when you turn? They did on my 33"s, I cut a little off the inside of the bumper where you can't notice. Problem solved.
I have a 3" front, 4" rear Rancho lift, not sure if those are still made. When I got the lift installed, the nose was down as compared to the back. I just removed the spacers under the leaf springs to level it out.
Old Jul 24, 2013 | 01:09 AM
TexasGuy001's Avatar
TexasGuy001
Superlift and BDS make good leveling coil springs. I think the Superlift part number is 117. All you need is the springs and an alignment. They will raise the front about 1.5 to 2 inches. I have the Superlift springs on mine. Another good option are the Moog replacement F250 front coil springs. They will lift the front about the same. I think their number is CC844.
Sdowdle541
16
Feb 1, 2015 01:23 PM
Dlasure2
Aug 10, 2010 10:13 PM
hughjazz
Dec 16, 2008 12:08 AM
GammaDriver
Jul 7, 2002 08:59 PM
