Coolant Leak
Old Jul 23, 2013 | 04:00 PM
johnwleong's Avatar
johnwleong
Coolant Leak
Hi,
I am new to ford trucks well actually trucks in general and new to this forum
I just bought a 1991 F-250 Super Duty 7.3 IDI diesel Truck
Just noticed today after starting the engine and moving the truck a little that coolant was leaking from the bottom of the truck.
I got under and took a picture of where it seemed to be coming from.
Does anyone have any ideas of what it could be. I am pretty handy around cars but not trucks. Would it be something that I should get a mechanic to look at?
Thanks in advance.
John
Old Jul 23, 2013 | 09:13 PM
johnwleong's Avatar
johnwleong
Got the Photo Working
Sorry I realise that the photo didn't load before.
Here is the photo of where the leak is hapenning.
Thanks
John
Old Jul 23, 2013 | 11:09 PM
Encho's Avatar
Encho
The Southernmost Mod
Hey, welcome to FTE and to our lil' corner!. Start the engine and look at all the coolant hoses above this spot, specially the ones coming from the water pump (check both the connections and the condition of the hoses, cracks, etc...), also check the pump bearing and weeping hole (any of these symptoms will indicate the pump requires replacement).
Old Jul 23, 2013 | 11:22 PM
RIKIL's Avatar
RIKIL
Like Encho said, you got to look up. Water will leave a trail from where the source is. Start looking above the seal there and try to find more water.
If you run the motor for a few min, it should get warm enough to evaporate any water that isn't in the path of the leak. Shouldn't be too hard to find
Old Jul 23, 2013 | 11:53 PM
johnwleong's Avatar
johnwleong
Thank you for your responses. Will have a look in the morning. I have worked on cars before and now working on a truck. There is soo much more room...
Thanks again.
Old Jul 24, 2013 | 01:32 AM
Encho's Avatar
Encho
Like you said, it's exactly the same, but with more space and bigger parts... and 4WD if you have it.
Old Jul 24, 2013 | 03:30 AM
90'F150's Avatar
90'F150
Where's this weeping hole? I got a pinhole leak but its more by the radiator and that's definite because I just replaced all hoses and the water pump and double sealed it with no leaks from it.
OBS Rock Lobsta
Feb 27, 2017 03:48 PM
VaFordman26
Apr 14, 2014 09:58 PM
jspence105
Nov 3, 2012 08:52 AM
65F100390
Nov 5, 2010 04:53 PM
drbigknuckles
Jan 28, 2009 04:05 AM
