EGR delete and program out?
Old Jul 22, 2013 | 09:17 PM
JaySVX's Avatar
JaySVX
I need to program my egr out so I don't get codes for it. I'm told I need to buy a tuner, but I don't want to do anything else with it. What's the cheapest way I can modify the computer to forget about the egr?
Old Jul 22, 2013 | 09:54 PM
dlibson's Avatar
dlibson
SCT tuner is the way to do it.
Old Jul 22, 2013 | 10:09 PM
Lilpooh's Avatar
Lilpooh
IIRC, the only two programmers available to do what you want are the SCT devices or Power Hungry Performance (PHP).
BTW, I work in Collegeville. Hi neighbor!
Old Jul 22, 2013 | 10:23 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
SCT Trans Only tune and EGR Off is a way to make sure the CEL doesn't set and you're running stock.
Josh
Old Jul 23, 2013 | 07:37 AM
JaySVX's Avatar
JaySVX
I was afraid of that. Seems I'm going to be spending a chunk of change then.
Old Jul 23, 2013 | 07:45 AM
Bullitt390's Avatar
Bullitt390
Depends on what strategy you too. I have an old strategy it doesn't set a CEL with the EGR delete
Josh
Old Jul 23, 2013 | 08:04 AM
olfordsnstone's Avatar
olfordsnstone
Josh
Josh, is this for your 2006 MY? How do you go about getting an "old strategy" on an 06 MY? I didn't know we had that choice when reflashing. My 2005 has always thrown a CEL, ever since the egr quit flowing crud into the intake. SCT tuner took care of that, though...
Old Jul 23, 2013 | 08:37 AM
Lilpooh's Avatar
Lilpooh
The common tuner to turn off EGR is the SCT, because you have many custom tune writer to choose from. The other benifit to buying your own SCT is, if you need to have the truck worked on by a shop/dealer, you can return back to stock tune. A SCT X3 with custom tunes range from $425-$429 with 3 to 11+ custom tunes included in the price. Another cheaper option is to buy a used SCT device, be sure it's unlocked and has unlocks left. Here is a post on what to look for when buying a used SCT device.
https://www.ford-trucks.com/forums/1...sct-tuner.html
The cheapest option would be to "borrow" or buy a PHP gryphon ECM tuner. If you "borrow", you deposit $250 and pay $150 for the EGR/tune. After you tune your PCM, you return the Gryphon and get your deposit back. The Gryphon can also be used to "roll back" the PCM strategy to a preferred stock program.
Power Hungry Performance - FICM Reprogramming
Old Jul 23, 2013 | 08:46 AM
Bullitt390's Avatar
Bullitt390
My truck was last dealer flashed January 2007. Pretty sure all flashes released from February 2007 to late 2009 are guaranteed to set a CEL for an EGR delete.
My results aren't scientific by any means but out of curiosity I tried over 3000 miles stock with an EGR delete and never set a CEL.
I still use a tune 95% of the time.
For those wanting to run stock and remove a CEL an SCT on Trans Only is the best way IMHO
Josh
Old Jul 23, 2013 | 10:48 PM
BLADE35's Avatar
BLADE35
Why I try to do all my own work so they don't slip a dif stratigy in on me
Old Jul 23, 2013 | 11:04 PM
BLADE35's Avatar
BLADE35
oh hows the truck running Now
DieselCamper
Oct 13, 2025 01:56 AM
Mike1016
Jul 19, 2018 12:57 PM
GSchretter
6.4L Power Stroke Diesel
Jul 26, 2013 09:15 PM
wyoguy
Jun 20, 2006 10:08 PM
