Oil Pump Wrong?
Old Jul 21, 2013 | 05:01 PM
JB78f150's Avatar
JB78f150
Oil Pump Wrong?
The oil pump doesn't look like it is square in the hole for the distributor. Looks like it is crooked or something.
Anyone ran into this before?
Old Jul 22, 2013 | 07:38 AM
Filthy Beast's Avatar
Filthy Beast
You have the correct oil pump for your M block?
There's only two bolts that hold the pump on, and it can only go on one way. Do you have the hex shaped drive rod lined up correctly? That little snap ring type deal goes to the top.
Old Jul 22, 2013 | 08:47 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Sounds normal. Hex shaft will move side to side. I usually place a dab of Vaseline on it to center it when installing distributor.
Old Jul 22, 2013 | 09:21 AM
JB78f150's Avatar
JB78f150
It took a while but finally got it straightened out so it would go into the bottom of the distributor.
flamesoldier
May 7, 2013 12:08 PM
79fordrat
Oct 21, 2012 04:13 PM
F.Phipps
Dec 17, 2007 05:43 PM
Matt Wilson
Feb 22, 2005 09:32 AM
Polkat
Oil & Lubrication
Nov 17, 2002 02:25 PM
