urgent (kinda)
Old Dec 17, 2007 | 05:27 PM
F.Phipps's Avatar
F.Phipps
urgent (kinda)
ok so wre woreking on my truck now.we got the oil pump in but cant figure out whjere the driveshft for it goes. if you hae a picture of a site with a picture please let me know like now haha
thaNKS
Old Dec 17, 2007 | 05:29 PM
95F350XL's Avatar
95F350XL
The drive shaft goes in where it bolts up 2 the bottom on the block. If you take out the distributor it goes into the bottom of that. The dist turns the oil pump.
Old Dec 17, 2007 | 05:37 PM
F.Phipps's Avatar
F.Phipps
does the distributor have to come out?
and do you have a picture?
Old Dec 17, 2007 | 05:41 PM
superduty4x4's Avatar
superduty4x4
Dist. has to come out to put the oil pump shaft in as far as I know.
Old Dec 17, 2007 | 05:43 PM
95F350XL's Avatar
95F350XL
No I do not have a pic. But it you pop your dist cap off, use a sharpie to mark where the rotor is on the housing. Then take the 13mm bolt out that holds the dist down and pull it up. When the dist rotor stops spinning make a mark where it stops with the sharpie. Then when you put it back in. You can get it in the same way.
