Replace A/C Components - Still Problems
Old Jul 21, 2013 | 07:09 AM
morganbryane's Avatar
morganbryane
I have an 04 Excursion which I just replaced everything with the exception of the two evaporator cores (front and rear) which were flushed along with all the a/c lines. The sticker under the hood said the system takes 4lbs 4oz of refrigerant. I vacuumed the system for 2 hours and no leaks afterwards. I charged the system with 5.3 12 oz cans of refrigerant and the service manual specs say 14oz of pag 46 oil. When I first started it up after the repairs everything seemed to work fine. I drove the truck a few hours I saw really high pressures 100+/410+ at about 95 degrees.
Today I wanted to get new readings. With the engine cold, the pressures were 85/100 a little low and I probably have a leak somewhere. I drove it for 10 miles and the pressures were 52/340 at 70 degrees. So it seems like I have high/high situation. The Ford service manual diagnostic charts says it is the condenser (inadequate air flow). Could I have gotten a bad condenser from the parts store? Any other thoughts?
Old Jul 21, 2013 | 09:04 AM
EXv10's Avatar
EXv10
You might have to take that one to an AC shop.
Old Jul 21, 2013 | 01:35 PM
morganbryane
Thanks, but I'm not ready to take it to an A/C Shop just yet. I will return/replace the condenser before I do that.
Old Jul 21, 2013 | 04:53 PM
X4The6-Pack's Avatar
X4The6-Pack
Replaced receiver/dryer too, or as part of the condenser? I've seen vehicles hold vacuum just fine, but leak under pressure.
Bruin008
Jun 11, 2019 07:19 PM
DirtyLarry
29
Jul 25, 2015 02:07 PM
BLADE35
Aug 28, 2011 06:41 PM
fmr9
Aug 9, 2006 01:02 PM
sirkt
1978 - 1996 Big Bronco
May 19, 2006 11:56 AM
