messed up lighting
Old Jul 20, 2013 | 04:36 PM
MrTisLost's Avatar
MrTisLost
messed up lighting
'78 Ford F150. Can't figure out what's going on with my lights or where to start.
1. With headlights on, the right front/back lights both filaments of the bulb are on, but on the left side, just one filament is on.
2. Blinkers: right rear works, but not r-front. Left front works, but not rear
I've swapped bulbs and replaced fuses but no nothings changed.
A bad wire or short somewhere? Where do I start?
john
Old Jul 20, 2013 | 05:24 PM
HIO Silver's Avatar
HIO Silver
Step 1. Get a Voltmeter.
Step 2. Learn how to use said Voltmeter.
Step 3. Review wiring diagram for 78-150. Link available here in the Electrical section: https://www.ford-trucks.com/forums/1...l#post13139591
Step 4. Test circuits for shorts, opens, grounds, and voltage.
Welcome to FTE.
Old Jul 21, 2013 | 12:08 AM
brian1080's Avatar
brian1080
90% of electrical problems with these trucks are bad grounds or corroded contacts. 9% is turn signal switch and the other 1% is random.
99% of percentage numbers are made up on the spot, but I'll bet I'm close.
Old Jul 21, 2013 | 02:18 PM
1972RedNeck's Avatar
1972RedNeck
If the electrical system is doing something impossible, it is a bad ground.
MN76
Jun 13, 2015 03:36 PM
rich51fordtruck
Electrical Systems/Wiring
May 23, 2009 09:02 PM
slntnddly
Oct 30, 2004 03:46 PM
dfisher1
Aug 5, 2004 12:45 PM
$150_4x4
Apr 16, 2003 08:01 PM
