at my ends
at my ends
I HAVE A 2002 F450 7.3 DIESEL I HAVE A PROBLEM I CANNOT FIGURE OUT MY TRUCK STUMBLES AND WILL NOT ACCELERATE AND HAVE THE HARDEST TIMES GOING UP A HILL I CANNOT CATCH SPEED ITS SHAKES SPUTTERS AND REFUSES TO GO. LIST OF THINGS I HAVE DONE IS CLEANED TANK NEW SENDING UNIT IN TANK NEW FUEL PUMP NEW FUEL FILTER NEW FUEL PUMP REGULATOR NEW VALVE COVER GASKETS ADN HARNESS NEW ICP NEW IPR I AM LOST AND DONT KNOW WHAT ELSE TO DO ALSO TOOK OUT ALL INJECTORS AND PUT NEW ORINGS ON THEM AND INJECTOR TEST SAYS ALL INJECTORS ARE GOOD ONLY CODE WILL SHOW UP IS LOW BOOST
It could be anything. Fuel/air. You can't just look for a boost leak! Make a boost leak detector... Tell us a little more about your truck you have us limited information. Does it have gauges? If so what kind of boost are you making? Is it tuned? Have you checked fuel pressure?
Wat do you think left that could make me have low fuel psi with all the things I have changed
I had the exact same symptoms as you, and considering you were messing around in the tank, my guess is that you made the same mistake as me. When I did my hutch mod I accidentally swapped my pickup line with my return line on the cap of the tank. Therefor I was trying to suck the amount of fuel a 3/8 hose could support out of a 5/16 line. Once I dropped the tank and switched the lines back, all problems were solved.
My $.02
My $.02
My $.02
My $.02
Reps.
