Red's Headers hitting steering linkage on bumps...anyone else had this?
Old Jul 19, 2013 | 06:42 PM
jhaas63's Avatar
jhaas63
My Red's Headers fit my flathead great and went in pretty easily. I have my true dual exhaust all done except I am noticing a problem. The headers hit the steering linkage on bumps on the road. It is isn't a real serious issue but I plan to take out some of the leafs to lower the truck and I dont want to break off a header bolt.
I have read many praises on here about Red's. Anyone having this problem as it is hard to believe it is only my truck?
Old Jul 19, 2013 | 07:23 PM
HD74's Avatar
HD74
They do guaranteed them, a picture would help.
Old Jul 19, 2013 | 09:57 PM
ALBUQ F-1's Avatar
ALBUQ F-1
On BonusBuilts their headers are almost a foot above the connecting link. Are you running center-dump headers?
Old Jul 22, 2013 | 12:03 PM
jhaas63's Avatar
jhaas63
Well, here are the photos finally. I spoke with Jim at Red's. He told me that it may be my motor mounts? He said they originally made these for an F250 but from the looks of Ross' photo, the bigger trucks have alot more room than an f100. Thoughts?
Old Jul 22, 2013 | 12:22 PM
AXracer's Avatar
AXracer
You could dent in that pipe a little bit to clear.
Old Jul 22, 2013 | 01:19 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Different type of headers than mine. I don't see how that's going to work, you need at least three more inches to allow for axle movement, and you're talking about lowering it further. Long-tube headers on a flathead don't do much good, see if Red's will take them back.
Old Jul 22, 2013 | 03:01 PM
jhaas63's Avatar
jhaas63
I know from searching on here, I am not the only one with a flathead and longtubes on here...
Would new motor mounts make a big enough difference and do I need to pull the motor to change them?
Old Jul 22, 2013 | 03:08 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You can't really change the mounts on a '53, they are on the bellhousing.
Old Jul 22, 2013 | 04:37 PM
jhaas63's Avatar
jhaas63
Headers - ’53 Pickup Modern [3462] - $250.00 : Red's Headers, Speed Equipment For Old Fords
Here is the link to Reds for the 53 f100.
Old Jul 22, 2013 | 04:56 PM
AXracer's Avatar
AXracer
Could you use the tie rod extensions made for dropped axles?
Old Jul 22, 2013 | 07:27 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I have to wonder if the "Modern" designation on Red's ad means Mustang II suspension.
Old Jul 22, 2013 | 07:40 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
That was my first thought,(tie rod exts)
Old Jul 22, 2013 | 08:08 PM
jhaas63's Avatar
jhaas63
Ross, Red's makes these headers for the truck I have with stock suspension. I have talked to them. They know what I have and have seen the pictures and they are telling me that the only problem they have ever had with this type of issue is very worn motor mounts.
They are not for a M II type of suspension. Long tube headers look the best, imo.
Old Jul 22, 2013 | 08:44 PM
AXracer's Avatar
AXracer
Have you rebuilt the motor mounts?
Old Jul 22, 2013 | 08:47 PM
jhaas63's Avatar
jhaas63
Nope, but I plan to look at them. It should be on a hoist in the next week or two.
