Ranger mirror adjustment?
Old Jul 19, 2013 | 04:10 PM
webly's Avatar
webly
Man, I've been away from the forum for so long that I forgot my password!!!
Finally got it and need to ask if there is any way to tighten the tension on the two rear view mirrors on either side of my '91 Ranger. They've become so loose that just touching them in walking by in my way-too-crowded garage bumps them out of proper focus. I've looked for some hidden set screw, or other tension device but found none.
So is there a hidden set screw or something I can tighten?
Or if not, what do you guys use to tighten the mirrors up so they stay in place but can be adjusted if necessary? There must be some secret to this.
Thanks in advance,
Jack
Old Jul 20, 2013 | 06:27 PM
Old93junk's Avatar
Old93junk
Those mirrors are garbage, once they get that bad there is no saving them.
Go to a wrecking yard and get the swing away towing mirrors off another Ranger of similar vintage, just add 2 screws for the bottom mount.
Those black plastic ones are hopeless.
Old Jul 21, 2013 | 10:09 AM
Hank85713's Avatar
Hank85713
Look at ebay or go to an aftermarket place that sells the replacement mirrors. I put power mirrors on mine they were about $40-45 each. Also L&M truck have replacement mirrors, but the stock ones even on ebay may be no better than what you currently have if they are used.
Old Jul 22, 2013 | 07:01 AM
piotrsko's Avatar
piotrsko
I've had some success with adding low force locktite to the joint. I have also used superglue but that made the joint immovable. the attaching mechanism is under the mirror glass so you have to break or otherwise remove the mirror glass to tighten it (ask me how I know this) There are not expensive replacements out there online or at auto parts stores, bought some, got myself the swing-aways off a junker anyways.
Old Jul 22, 2013 | 12:36 PM
webly's Avatar
webly
Thanks guys.
I was thinking about something along the lines of Locktite and I appreciate the confirmation from Piotrsko to at least give it a try. Let's see how big a mess I can make now!
Jack
F250_
25
Feb 17, 2015 02:51 AM
belen1705
Oct 5, 2012 11:17 AM
Furyus1
13
Sep 30, 2010 10:23 PM
DanMan7
May 9, 2004 06:10 AM
waingraves
Sep 2, 2001 11:24 AM
