Does anyone have a step by step instructions for condenser replacement.
Can't find anything on the net or this site. Does the radiator have to be removed? Does the inter-cooler need to be removed. The bottom condenser bracket nests under the inter-cooler. Its looks like another engineering marvel.
I recenyly replaced my condenser ('05-e450), it was very easy after taking off the plastic shirld etc (on top), the condenser will "slide" out (up) from the mounts, no other bolts, and it clears the oil cooler also, only the a/c hose/tubes need to be un-screwed with a wrench.....jerry,(I hope this helps-I think the "front with raditor) is almost the same)
