460 engine swap question
Old Jul 19, 2013 | 01:52 AM
inhonorofchuckgehner's Avatar
I am swapping in a 460 to my 78 150. The engine is from a car and the alternator is low on the passenger side about 1/4" from the frame. Besides buying the brackets from L and L or making some up what has anyone else done that has run into this problem?
Old Jul 19, 2013 | 07:11 AM
jim collins's Avatar
jim collins
This is the 460 engine that came in my 79 F-150 super cab and as you can see it was mounted low on the passenger side. I believe you just need to look for a 78 / 79 truck bracket. If i still had the engine i could get the part number off of it for you . It may be that "Number Dummy" will do that if he sees this thread.
Old Jul 19, 2013 | 08:49 AM
mikeo0o0o0's Avatar
mikeo0o0o0
The parts catalog shows three pieces make up the alternator mount for the '78 F150 w/ 460, the front bracket, the adjustment arm and spacer.
Front bracket D0VY-9B450-A
Spacer (cut to fit) D0VY-10A370-A
Adjustment arm D0SZ-10145-A (Motorcraft p/n GY-939)
This is one of those part numbers that's quite often entered into inventory with a wrong number. The zero is often eneterd as an alpha "O" instead of the numeric "0". I search both ways.
With the p/n as zero
Front bracket
The Lincoln/Mercury Old Parts Store, Clearwater, FL has 2 (727) 445-7551
Adjustment arm
Wesley Obsolete Parts, Liberty, KY has 1 (606) 787-5293
With the p/n as "O"
Front bracket
Vintage Parts, Inc., Beaver Dam, WI has 3 (877) 846-8243
Sunbury Motors, Sunbury, PA has 1 (570) 286-7746
Dickerson Motor Co., York, SC has 1 (803) 684-4225
Adjustment arm
Dickerson also has 1 of these
Spacer
Bob Allen has one, but trust me, easy to fabricate and MUCH, MUCH cheaper than buying from Bob Allen .
Old Jul 19, 2013 | 12:16 PM
jim collins
I knew there were some more parts that are not in that picture but i forgot what they looked like. That engine has been gone for sometime now and i thought some body would come along with those numbers . Hope that helps him .__
mark a.
Jan 4, 2012 08:22 PM
79driver
Feb 11, 2007 11:17 PM
Handegard
Jun 16, 2006 05:16 AM
GeorgeinMaine
Jan 26, 2005 11:58 AM
idahocrewcab
Nov 21, 2000 08:23 AM
