Do I need to replace BOTH sway bars?
Old Jun 12, 2003 | 11:16 AM
franklin411's Avatar
franklin411
I've got a 96 Ford Explorer XLT 4.0 2 WD 4 Dr, and I'm going to replace the front sway bar for sure. I was wondering if I need to replace the rear sway bar as well. Everything I'm seeing on the net says that the front sway bar should be replaced with a larger/solid sway bar, but they say nothing about the rear. I don't want to spend $150 replacing a 7/8" rear sway bar with the same exact 7/8" rear sway bar. Thanks!
Old Jun 12, 2003 | 11:18 AM
franklin411
PS--I know that the Explorer express sway bar kit comes with larger diameter front and rear sway bars, but none of the other manuf. does this. They all go larger in the front, and 7/8" in the back. I'm also wondering if I can just replace the front bar only and see how much better it gets. Is that safe?
Old Jun 12, 2003 | 05:34 PM
WillieTD's Avatar
WillieTD
It's safe, but I would change both. You'll get greatly improved handling that way. I'm no physics professor, but if you're changing the front and not upgrading the back, there may be some effect in understeer/oversteer.
Also, since it sounds like your interested in better handling, lowering even an inch would help greatly. You can buy lowering kits for the rear in Autozone or Advance for $20.00 and just torsion twist the front until it matches the rear height.
Old Jun 12, 2003 | 11:24 PM
reberhardt's Avatar
reberhardt
In addition to Explorer Expresses swaybers, you can also get Addco (www.addco.net) and if you can find them Saleen (they apperently stopped making them). I installed Addco swaybars front and rear on my '97 4x4 lifted Sport and I can tell a definate difference. Your stock rear bar isn't 7/8", it should be 5/8". The aftermarket bars are usually 7/8" or slightly larger. I can't say how much of a difference just the front made though since I did both at the same time. Installing just a thicker front swaybar will tend to make your vehicle push (go straight when you want to turn) a little easier. You really should replace both to keep the system balanced. It won't be bad though with just the front since basically that is what Ford did to the Explorer starting in '98. They swapped out the huge (IE hollow) front bar that they used for the '95-'97 Explorers and put on a solid (IE thinner) bar that is much stronger. They left the rear untouched. A lot of swaybar manufacturers offer front/rear kits for '95-'97 but rear only kits for '98 and up since they claim the revised one from '98 is sufficient.
Old Jun 12, 2003 | 11:49 PM
WillieTD's Avatar
WillieTD
Yeah, I forgot about Addco.
Jermafenser
May 22, 2015 04:43 PM
Baldy66
Apr 9, 2015 09:20 AM
EODguyJake
6.7L Power Stroke Diesel
Nov 10, 2014 08:51 PM
TheHouse
Mar 31, 2009 09:37 PM
