Sway Bars
Old Apr 4, 2015 | 10:21 AM
Baldy66's Avatar
Baldy66
Sway Bars
I have 55 with a Mustang 2 front. I'm planing on converting to coil overs front and back with a RideTech triangular 4 bar kit. Now my question, I have asked several venders about sway bars. Some say front only and some say rear only. When I searched most of you have said both. Looking for options as to which way to go. Thanks!
Old Apr 4, 2015 | 11:06 AM
AXracer's Avatar
AXracer
IFS: swaybar mandatory. Triangulated 4 link rear: optional, depends on front bar stiffness, shock valving, lowering, type driving. No single right answer.
Old Apr 8, 2015 | 08:17 PM
Baldy66's Avatar
Baldy66
Thanks Ax for the info
Old Apr 8, 2015 | 11:23 PM
AXracer's Avatar
AXracer
Try it without first. I wrote a detailed post on how shocks and sways function and work together that might help you decide. try a search on swaybar and my user name. Are the coilovers adjustable (valving)?
Old Apr 9, 2015 | 07:12 AM
Baldy66's Avatar
Baldy66
What I was looking at were Viking double adjustable coil overs. I am not sure what length of shocks as I will be using the truck for street use only. For the front sway bar I would like to use will be a minimum of 1"or leaning toward 1 1/8" on the front. Thanks
Old Apr 9, 2015 | 09:20 AM
emay's Avatar
emay
I'm in a 53 and also spoke with AX in PM's about my plans. He recommended the same for me, try the rear without, go from there. I felt the rear sway was necessary after about 3 minutes of spirited driving.
Set up is as follows:
Front - 71 Firebird front clip, HD springs (everything else sagged under the BB motor), monroe shocks, Helwig 1-5/16" front sway.
Rear - Welders series triangulated 4 bar, welders series sway kit (passed thru frame) QA1 fully adjustable coil overs - 275# springs.
Truck handles and tracks fantastic now.
49 Ford F-1
Bronco II
May 2, 2019 12:19 PM
Mustangtc65
Dec 21, 2017 02:42 PM
davecarpe
May 26, 2008 11:09 AM
shivelyt
Apr 3, 2004 09:42 AM
Mil1ion
Jan 10, 2002 01:49 PM
