Speaker hole sizes
Old Jul 18, 2013 | 02:43 AM
stercorarius's Avatar
stercorarius
Speaker hole sizes
Does anyone know what size and depth the speaker holes in the doors and center of the dash are? It's a 1975 f150 custom if the model had anything to do with it. If there is another hole that I am unaware of, that information would also be greatly appreciated. If you have any tips, tricks, or recommendations that you have picked up regarding installing speakers I'd be glad to hear 'em.
Old Jul 18, 2013 | 04:52 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Original door speakers (18808) 5 1/4" diameter.
Old Jul 18, 2013 | 08:32 AM
fmc400's Avatar
fmc400
MSEE
6.5" speakers fit my doors perfectly; I just had to re-drill the mounting holes. Note that the diameter of the cutout itself is not the same as the industry-standard size you need to use; the industry-standard measurement includes the mounting flange.
Conduit ran in the door jambs:
Old Jul 19, 2013 | 11:53 PM
Jayman1976's Avatar
Jayman1976
Like fmc400 I also mounted two 6.5" round speakers in the doors. Don't cut the doors below the door panel! The hole in the dash I believe takes a 6"x4" speaker or 7"x5". Whenever I removed mine I measured it and it was a funky size that isn't made much anymore. But I have seen people shove 6x9's up there if I remember correctly. Personally, I put two tweeters up there in the dash. I've got four 6x9's, and two 10" subs behind the seat. I put the amps underneath the seat. Not much room for much of anything behind the seat now... It's a little overkill, but man does it have some serious power and thump to it since its all in a regular cab '76.
Old Sep 13, 2013 | 12:49 PM
highoctane74's Avatar
highoctane74
I mounted the 6.5" focal's in my doors. I ended up having to trim the hole a little bigger, and hammer and dollied it flat. These speakers are huge compared to my old ones.
Old Sep 14, 2013 | 01:37 AM
ihc1470's Avatar
ihc1470
Fmc400 where did you get the door conduit?
Old Sep 14, 2013 | 01:46 AM
keiths78f150's Avatar
keiths78f150
You can find them at Dennis Carpenter.
Part # D3TZ-19A123-A $20ea
Old Sep 14, 2013 | 07:25 AM
fmc400's Avatar
fmc400
MSEE
I bought a spool of it from Lowe's.
monkey-1
Feb 2, 2024 11:10 AM
wizzy214
Mar 4, 2013 09:34 AM
sturoe
13
Sep 23, 2006 08:41 PM
whistling69deuce
Jul 21, 2005 10:06 PM
300Runner
Aug 6, 2002 06:49 AM
