I've got a '97 E250 with what appears to be the factory tow package- it has all the fuses and relays under the hood, and I've got a plug by the e-brake that connects to my brake controller (which gets power at this point)
I've been given a part number from Ford (xc2z13a576ba) for the factory harness. They say it should plug into a existing pair of connectors under the body someplace.
From what I understand, someplace on the van there is a connector or pair of connectors that has the 7 signals for my trailer plug. But where is it? I put the van on a lift today, and I didn't see anything jump out at me from below.
It is a extended cargo van if that makes a difference. I did a search, and all I got was results looking for the other end of the plug, the one the brake controller plugs into...
