wheel offset difference?
Old Jul 17, 2013 | 01:34 PM
Gerby Dutchy's Avatar
Gerby Dutchy
Hi I just got new rims and tires on my f150 2009 but I noticed that on the passenger side the tires stick out about 1.5 inch more than on the driverside how is that even possible?
Old Jul 17, 2013 | 03:05 PM
04XLTRUNNER's Avatar
04XLTRUNNER
Might want to check your rims. they might have sent 1 with a different backspacing or offset.
Old Jul 17, 2013 | 05:33 PM
QwkTrip's Avatar
QwkTrip
So.... did you ask the tire shop that question? Might want to start there before you try asking people on the internet that can't even see your truck.
Old Jul 17, 2013 | 09:36 PM
Gerby Dutchy
yup, I asked the tire shop and they told me that all 4 boxes had the same part no.
so they should be the same and its just odd that it's only the passenger side but i'll go to the tire shop this saturday and find out i guess
Old Jul 17, 2013 | 10:39 PM
QwkTrip's Avatar
QwkTrip
Is it just the front, rear, or both front and rear that stick out so much? The body of any vehicle is not perfectly centered over the suspension but 1.5 inch difference in body clearance is way too much to be considered normal.
There is something you can do at home before going to the shop.
  • Use a tape measure to measure the wheel depth from brake rotor to the outside lip of rim. Use a straight rod or board to span across the wheel so you have a common perpendicular reference point on the outside lip of wheel (In other words, don't measure by eye). See if there is a significant difference from one wheel to the next.
  • Also verify all tire sizes are same. Slap a board on each side of tire and measure the width of tire. (Again, don't measure by eye.)
If those measurements don't reveal major differences then it's likely the body isn't centered over the wheels or the wheel alignment (caster) isn't same side-to-side.
Old Jul 19, 2013 | 08:45 PM
shatfieldj's Avatar
shatfieldj
Glad I saw this post. Thought I was losing it today. I was checking out my truck today and I thought that the passenger tires were sticking out further on the passenger side than on the drivers side. Not 1.5 inches, but noticeable i thought. I kept going back and forth looking at each side. Looked crazy. I thought I was just seeing things. Just going by the eye. Didn't take any measurements, but will do so tomorrow. Kinda dark out now. I only have 200 miles on the truck. Thanks.
Old Jul 20, 2013 | 06:14 PM
Gerby Dutchy
It is actually just the rear passenger side , the tire shop guys were very confused too ,they measured the width of the 2 rear rims and put both rims on the floor and measured from the floor to where the rim normally touches the hub these measurements were the same , tires are the same too
Old Jul 20, 2013 | 06:18 PM
Gerby Dutchy
I got a wheel allignment done last january they did replace the clutchpacks a few months ago maybe they pissed around with the rear axle?
Old Jul 20, 2013 | 08:07 PM
QwkTrip's Avatar
QwkTrip
Sounds like rear axle isn't centered under the body. Maybe loosen the bed body mounts and see how much you can move the bed over.
This is a common issue on old cars. Usually people will buy wheels with custom offset so the side that used to stick out is tucked in where it should be, and then use a wheel spacer on the other side to set the wheel out to look uniform with the body. Seems kind of silly you should have to do that with a new truck.
Old Jul 21, 2013 | 10:15 AM
Gerby Dutchy
i guess i could try that, there doesn't seem to be a way to move the rearaxle over ... or is there?
Old Jul 21, 2013 | 10:20 AM
QwkTrip's Avatar
QwkTrip
Not really. You'd be fighting the leaf springs.
Old Jul 21, 2013 | 02:52 PM
Gerby Dutchy
that's what i thought ,
but when i move the bed over then it might not be in line with the cab anymore
assuming that Ford makes sure that everything is properly lined up before leaving the factory
Old Jul 21, 2013 | 03:34 PM
SuperDutyScaler's Avatar
SuperDutyScaler
maybe the robot didn't feel good that Friday afternoon and wanted to go home early and get a ice cold robot beer
Old Jul 21, 2013 | 07:49 PM
QwkTrip's Avatar
QwkTrip
You're going to move the back of the bed only about 1 inch. Don't move the front of the bed if it's aligned with the cab.
Old Jul 22, 2013 | 01:26 PM
Gerby Dutchy
Ok I see ill give it a try one of these days then i'll let you guys know
