Best size tire?
Old Jul 16, 2013 | 03:53 PM
FunknFord's Avatar
FunknFord
Best size tire?
I have a 1962 Ford 100 step side 2 wheel drive truck that has had a 390 put into it.
When I got the truck it had some old junk tires and wheels on it.
I now have a set of 15x8" mag wheels to put on but am wondering what the best size tire would be for the truck? This truck is not going to be performance related, Probably just a weekend cruiser in the summer time.
The old rotted tires that were on the old wheels were 235/75/15's.
Old Jul 16, 2013 | 05:29 PM
SuperSabre's Avatar
SuperSabre
I put new 235/75 x 15s on my truck, but my wheels are 15 x 7. Since yours are 15 x 8, you could probably go a size or two wider.
Old Jul 16, 2013 | 08:39 PM
smokenchoken's Avatar
smokenchoken
these trucks will take up to 265 75 16s on the back without rubbing and take 245 75 16s on front with no problem either
Old Jul 17, 2013 | 12:22 AM
Pickupmanx2's Avatar
Pickupmanx2
Veteran: Marine Corps
I love 265/70/15's on 15x8 on 2wd, had them on my 70 Chevy also, get a lot of compliments, wide but not too wide
Old Jul 19, 2013 | 09:15 PM
smokenchoken
pickupmanx2 i love your wheels what design is that its awesome
Old Jul 20, 2013 | 01:17 PM
Macs1964F100's Avatar
Macs1964F100
I went with 235/75/15 because they are close to the original tire height and the most common light truck tire size which makes them easy to find and relatively inexpensive. I have Wranglers which have a rounded sidewall and would be perfect for a Jeep or SUV. I would prefer a straighter sidewall for a more traditional look. I will get a different tire when I get a set of innie wheels and bottle cap hub caps. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Jul 20, 2013 | 11:02 PM
customcab66's Avatar
customcab66
I put 31x10.5 on my 66 2wd and it upped my gas mileage about 5 miles to the gallon and I also have a 390 in it
Old Jul 21, 2013 | 12:03 AM
66f-100's Avatar
66f-100
Did you have any issues with the rear tires rubbing?
Old Jul 21, 2013 | 11:27 AM
customcab66
not the rear wheels the front tires rub a little if you are in a hard corner and your bouncing it around they just touch the fender but not to bad
Old Jul 21, 2013 | 02:49 PM
customcab66
not sure how to post a pic here but if you go to my gallery there is a pic of the tires on the truck
Old Jul 21, 2013 | 02:55 PM
customcab66
[/IMG] hope this works these are my tires
Old Jul 21, 2013 | 03:58 PM
smokenchoken
you can put 32x11.50s on the back without rubbing unless on super rough terrain trust me on this i have even done it with 2 rick of wood in the back with no issue main problem i have run across is wheel depth offset being to far to the inside of the bed and 33x12.50 15s rub the inside of bed same as 285 75 16s
Old Jul 22, 2013 | 10:00 AM
Pickupmanx2
Thanks!
Black Rock rims, I really like them too
http://www.summitracing.com/parts/br...1237/overview/
Old Jul 23, 2013 | 12:58 PM
old broke prospector's Avatar
My 62 4x4 has 7.0 x 15. Narrow tires equal easier turning, break through the ice and snow to gravel easier. Note the heavy duty springs. Clearance is not a problem as this is a flatbed truck.
The red 66 250 up on the hill is my guard dog and emergency truck. No one wants her at $1500 so she may go to one of the grandkids in a dozen years or so.
Old Jul 23, 2013 | 03:24 PM
charliemccraney's Avatar
charliemccraney
I have 275/60-15 on the rear of my uni which is lowered about 2.5" At least a little bigger will fit.
smiler289
May 1, 2017 05:38 PM
jaygee15
18
Feb 23, 2017 04:29 PM
richiepan
18
Feb 3, 2011 10:24 PM
iceman320
Oct 1, 2009 08:55 PM
jomac11
Sep 6, 2007 08:08 PM
