16 and 17" wheels
Old Sep 30, 2009 | 11:04 PM
iceman320's Avatar
iceman320
16 and 17" wheels
ok so I have been thinking about putting new wheels and tires on my 78' f-150 and I have been looking at the 16 and 17" wheels the only thing is if I go up to the 16 and 17"wheels what size of tires will I have to put on the truck? does any body know? thanks in advance
Old Oct 1, 2009 | 08:55 PM
OrangeJuice's Avatar
OrangeJuice
I guess it depends on several factors like how tall of sidewalls you want? That will also deterime how tall the overall height of the tire will be. And the width of the tire and whether you have enough clearance on the back side of the tire to avoid any rubbing when the wheels are turned to max. Here is a helpful link I've used Tire Size Calculator - tire & wheel plus sizing - first go to vehicle stock tire size and type in the size you want and hit the compare tire sizes below. All the specs of that tire size will be available. Not sure what size tire you have on it now, but this will get you close.
Good luck
OJ
