Question about inertia switch
Old Jul 15, 2013 | 08:06 PM
erica's Avatar
erica
Question Question about inertia switch
89 f250 7.5 custom. I finally found it, but I am not sure if it is set properly. The plastic device has a small window opening where you can see red. Is this what I should be seeing? I have tried pushing the button on top and it doesn't move at all. So I would assume that unless it has tripped this is normal. I tried to post a picture but wasn't able to. I am asking because we are having troubles starting the trucks. Cranks strong but doesn't turn over. Thought I would eliminate the inertia as a problem.
Old Jul 15, 2013 | 08:11 PM
Cubawashere's Avatar
Cubawashere
yes pushed in position is correct. I haven't seen many go bad though.... Have someone turn the key to on position not cranking and listen for the pump by tank, it should wine for 2 secs then cutoff.... also they do have their own relay on the firewall, you could switch it with another of the same number.... also check for spark....
Old Jul 15, 2013 | 08:59 PM
GoinBoarding's Avatar
GoinBoarding
X2^^
My fuel pumps wouldn't run on a cold spring day this year. Inertia switch was not "tripped", but only after wiggling the wires connected to it did the fuel pumps run. My passenger side door seal is on the fritz, and I suspect some water caused the problem.
Miranda93
Jan 20, 2025 05:07 PM
joshua6430
26
Feb 13, 2017 12:54 AM
VannerDude
Feb 22, 2015 01:54 PM
lightningfan426
13
Sep 17, 2012 11:32 AM
ford91f150
Jun 17, 2004 09:23 AM
