Timing Gear and Chain
Old May 13, 2004 | 07:34 PM
AirSmitty's Avatar
AirSmitty
In the Jegs catalog they only have a timing chain ford 64-74 FE's. Did they change them in 75 and 76. All FE's should have the same timing set right? thanks.
Old May 13, 2004 | 08:46 PM
76supercab2's Avatar
76supercab2
I think later models had a timing set that retarded the cam timing. An earlier set that provides straight up timing would offer better performance.
Ratsmoker's Avatar
Ratsmoker
Yes and no. An FE timing chain is an FE timing chain but the 1972 and up chain was retarded 8 degrees for emmisions purposes and should not be used for a rebuild. Get a good performance chain even for a stock rebuild. It will last longer and the engine will perform better all around with the cam straight up.
