Carburetor
Old Jul 17, 2013 | 10:11 PM
Birdman_7137's Avatar
Birdman_7137
Assuming they fit, it this just a matter of tearing it apart and putting it back together with the new parts? Or is there tuning involved?
Old Jul 18, 2013 | 10:45 AM
JEFFFAFA's Avatar
JEFFFAFA
Well, first before removing ,gently screw the idle mixture screw all the way in while counting the revolutions. This will get you a starting point once back on the engine. Second, once it is apart you have to soak all the non-rubber parts in carb soak. It comes in one and five gallon cans. Your carb is small enough you should get away with the one gallon. Once it's soaked for a few hours blow out all the internal passages. Compressed air is the best way. Then rinse and wipe down. All the necessary adjustments will be explained in the instructions that came with your kit.
Old Jul 18, 2013 | 10:56 AM
Gembone's Avatar
Gembone
The rebuild can seem intimidating at first. Just go slow and take lots of reference pictures. It is easier than most people believe on a Carter YF.
300workhorse
40
May 25, 2018 07:41 AM
dwrestle
Nov 15, 2010 04:22 PM
bluegrasmtns
Feb 1, 2009 07:32 AM
clawhammer
Feb 15, 2007 06:23 PM
Mikes67F250
May 22, 2005 08:51 PM
