Dash lights
Old Jul 15, 2013 | 02:12 PM
Boodrow379's Avatar
Boodrow379
Dash lights
Well all my dash lights worked yesterday, I put in my radio and now none of them work. No flicker or anything. if i put power on the main wire with an alligator clip all the lights turn on but nothing happens when i turn on the headlight switch. The switch is new but could I have burned the dimmer or something in the switch? all other lights work
Old Jul 15, 2013 | 03:19 PM
Filthy Beast's Avatar
Filthy Beast
From where did you source power to the radio?
Not to be a wise apple, but do the lights work when you turn the radio on?
Old Jul 15, 2013 | 05:03 PM
fmc400's Avatar
fmc400
MSEE
Did you mistake the BLUE with RED stripe wire in the radio pigtail for ground?
Old Jul 16, 2013 | 09:42 AM
Boodrow379's Avatar
Boodrow379
Yes that is exactly what I did, crossed the blue and red striped one with the radio ground, still no dash lights with the radio on or off, and i cant find any burned wires or fuses. Thank you for the reply what do you think?
Old Jul 16, 2013 | 10:00 AM
fmc400's Avatar
fmc400
MSEE
I assume you have since corrected the problem, removing the previous connection to the BLUE with RED stripe wire and grounding the radio to the dash properly?
With the headlight switch pulled out to one of the two stops, turn the **** all the way counter clockwise just before it clicks into place to turn on the dome light, and check for power on BOTH sides of the instrument panel illumination fuse. How were you checking it previously?
Old Aug 11, 2013 | 11:15 AM
Boodrow379's Avatar
Boodrow379
[QUOTE=fmc400;13344867]I assume you have since corrected the problem, removing the previous connection to the BLUE with RED stripe wire and grounding the radio to the dash properly?
With the headlight switch pulled out to one of the two stops, turn the **** all the way counter clockwise just before it clicks into place to turn on the dome light, and check for power on BOTH sides of the instrument panel illumination fuse. How were you checking it previously?[/QUO
I'm kinda slow to reply lol, thank you for the advice but where is the insturment panel illumination fuse?
Old Aug 11, 2013 | 11:24 AM
fmc400's Avatar
fmc400
MSEE
It's in the fuse panel. It's one of the shorter ones and should be labelled something along the lines of "INST ILLUM", etc.
Old Aug 11, 2013 | 03:02 PM
Boodrow379's Avatar
Boodrow379
Yep you definitly know what your talking about, lol I was gonna buy a whole 30 dollar headlight switch but it was only a .50 fuse. thank you, have a good one
Old Aug 11, 2013 | 03:03 PM
fmc400's Avatar
fmc400
MSEE
Awesome, glad to hear you got it worked out.
WWR
2004 - 2008 F150
Jun 9, 2017 10:50 AM
Collision
Mar 10, 2016 08:33 PM
tut1000
Electrical Systems/Wiring
Oct 11, 2011 12:07 PM
74F2504by4
Oct 26, 2006 09:58 AM
nikidog11
Dec 8, 2003 03:53 PM
