dash lights questions
Old Oct 21, 2006 | 01:30 PM
74F2504by4's Avatar
74F2504by4
Question dash lights questions
This is probably a stupid question, but here goes. When turning the truck on, do the dash lights(the lights for the instrument panel) come on? I replaced the radio and I don't know whether the lights were on before that or not.
1974 F-250 Highboy 4x4
Thanks,
Patrick
Old Oct 21, 2006 | 02:02 PM
ivanribic's Avatar
ivanribic
The dash lights will come on any time the headlights or parking lights are on. The brightness of the dash lights is controlled by twisting the headlight ****.
The dash lights should not come on just because the ignition is on . . . I think that's what you're getting at?
Old Oct 21, 2006 | 02:20 PM
74F2504by4's Avatar
74F2504by4
yes, that's what is happening, when the ignition is on the dash lights come on. hmmm. I had electrical. I guess I will need to get a wiring diagram and figure it out.
Thanks,
Patrick
Old Oct 21, 2006 | 03:58 PM
Mil1ion's Avatar
Mil1ion
Sounds like someone has been fooling around with the wiring.
The Lighting circuit you are describing flows through a blue/red stripe wire.
It;s possible you are getting power feedback though the radio lighting wire.
The 2 wire harness to the radio carries power to the radio and power to the radio light.
That's where I would start looking for those wires spliced together .
Old Oct 23, 2006 | 01:46 PM
74F2504by4's Avatar
74F2504by4
Thank you Mil1ion for the diagram, it helps and you were right I connected the two wires together to the switched power wire of the new radio. It doesn't have a seperate radio light, so took off the one wire but then the lights do not come on at all even if when I turn the headlight **** out. Not sure what I can do now. I might just put the wire back on so I at least have dash lights at night. Thank you again for the wiring diagram.
Thanks,
Patrick
Old Oct 23, 2006 | 01:57 PM
Mil1ion's Avatar
Mil1ion
I assume the headlight switch is turned all the way for brightest.
Is this the Original Ford radio ?
Can you post a pic of the harness ?
Check the fuse with a multi-meter to verify the fuse is good
Just because they look fine doesn't mean it is..sometimes the ends of the filament breaks off but the filament stay "looking" good.
The harness on the radio should look something like this :
Old Oct 23, 2006 | 02:40 PM
74F2504by4's Avatar
74F2504by4
Negative, it is not the orignal Ford radio, it is the one from Blue Oval truck parts, it has the old school look, but it did not have the harness(no harnes at all, just wires) like the original radio, what I did was cut off the old harness and spliced it into the new radio(this is where I took both wires from the original radio side of the harness and connected them to the single switched power wire on the new radio. I am at work so I cannot get you a picture right now. Actually I just drew up in paint, I can't seem to paste it into this reply but I have uploaded it into my gallery it is the last picture. Thanks for the help.
Thank you,
Patrick
Old Oct 23, 2006 | 06:12 PM
Mil1ion's Avatar
Mil1ion
Okay so not we have to see why you don't have any cluster/dash lights.
Let me know if the fuse is good.
Old Oct 25, 2006 | 03:30 PM
74F2504by4's Avatar
74F2504by4
You know just color me stupid, I used a flashlight to check the fuse the other day and it looked good, but just to double check it last night I pulled it and sure enough it was blown. I disconnected the wire that used to go to the radio light and jut left it off, so the only thing connected was the new radio and I replaced the fuse and no **** sherlock . I told you I friggin hate electrical. I now only have two small other problems to chase down, the reverse lights(that fuse is good ) and when I switch over to the auxilary gas tank the gauge doesn't work which I already know is because of the wiring, the only wring that is connected is from the main tank. I'll have to take off the spare tire and run down where the wire is from the aux gas tank's sending unit if there even is one. Thanks for the help.
Old Oct 25, 2006 | 08:55 PM
Mil1ion's Avatar
Mil1ion
Check the NSS on the steering column for it being bad or out of adjstment.
This may be the cauuse of no BU lights.
I don't have the wiring diagram for the in-cab fuel tank system.
Old Oct 26, 2006 | 09:58 AM
74F2504by4's Avatar
74F2504by4
Thanks, I traced the wire from the main tank and I isn't the original wire and it is the only wire connected, I just have to find the other wire from the aux tank. I'll check the NSS this weekend. Thanks,
Patrick
