Weak 1990 7.3 dually
Old Jul 14, 2013 | 10:24 PM
ALedbetter1's Avatar
ALedbetter1
I've been fixing up our old farm truck, 1990 F-350 custom dually with a 7.3 and a 5 speed. Its got a dew-eze hay bed on it too. I'm almost done but there is 1 thing left to do. Ever since my grandparents bought it new in 1990 it has been notorious for having no power. It had a total motor rebuild by the local diesel shop in 2008, but it didn't change a thing. When compared to my 83 6.9 that has close to 300,000 on the clock, it is terrible. While there is about a 2000 lb difference between the two I would think the lower gearing in the tranny and rear end (4.10 Vs 3.55) would even that out. If I'm thinking wrong correct me but if not some simple tips on what I can do would be of great help.
Old Jul 15, 2013 | 12:11 AM
Wood.'s Avatar
Wood.
was the injection pump looked at? id start there.
Old Jul 15, 2013 | 05:38 AM
fellro86's Avatar
fellro86
When bought new in 84, the old man's 6.9 was a pooch. After the injection pump change later on, it woke right up. It may not need changed, but it may need tuned.
Old Jul 15, 2013 | 08:55 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
yeah,something's backwards.n/a to n/a,stock to stock,the larger 7.3l engine,should be the one with slightly more nuts of course.
in '08 when they (needlessly) rebuilt the engine,did they re-use the old medium ware items or swap them out for reman too? - ip and injectors.
how much do those beds weigh?
Old Jul 15, 2013 | 02:48 PM
ALedbetter1
The pump looks unchanged and considering that there are 2 stayndyne injectors 2 no names and the rest are I think bosch they didnt replace them either. the beds weight about 2000 to 2500 lbs give or take. Ive considered retarding the pump by turning the whole thing counter clockwise. This is what the diesel guy at oreillys suggested. Any thoughts or comments on this?
Old Jul 15, 2013 | 06:41 PM
FORDF250HDXLT
she really could just use a total tune for starters.anything less would likely not be worth the time.since she's been reman now,it really would be sad to not see the medium ware items changed out and have the timing properly set.she'll be around for a great many of years now.
https://www.ford-trucks.com/forums/1...p-ratings.html
Old Jul 15, 2013 | 06:50 PM
fellro86's Avatar
fellro86
I doubt retarding the timing really will be the trick, the timing needs to be set to the proper time, and maybe fuel turned up. If you retard the timing, depending on how it is now, you will be chasing the piston down, not driving it down. Advancing would seem more reasonable to me, but there are too many factors at play to know just from a simple lack of power complaint. Heck, it could just simply need the fuel filter changed!
Old Jul 15, 2013 | 10:06 PM
ALedbetter1
I'm really beginning to think there is more wrong here than I originally hoped for, and you guys are probably spot on. When I replaced the seal on my 6.9s injector pump housing adapter we got the pump on with it slightly retarded it had good power but at a idle the whole truck had a shake to it and smoked a lot. With just a slight twist clockwise it stopped the shaking and the smoke. This is why I thought retarding it might help some because at an idle its smooth and I could not get it to even puff a bit of smoke. So I went ahead and turned the pump counter clockwise and it didn't change anything it turned about a 1/4 inch and its like I didn't even touch it I mean no change whats so ever. I'm no expert but i don't think its supposed to work like that.
Old Jul 16, 2013 | 05:29 AM
fellro86's Avatar
fellro86
Unless it was over advanced, retarding it would only make the problem worse. It works essentially the same as retarding a distributor on a gas motor. The only difference is the fuel availability. The later you inject the fuel, the less compression heat you have to ignite the fuel.
Old Jul 16, 2013 | 09:20 AM
ALedbetter1
You guys are right. I will have to do a little research and find someone around here to tune it after I replace all the injectors and such. The only place that I know of are the people who rebuilt it and I'm not a big fan because they say they do all diesels, but 99% of their work is on performance Cummings. They either don't care or don't want to work on the ford diesels.
turp
Jan 20, 2013 01:40 PM
lindar2177
Dec 19, 2008 10:08 PM
boggle
Jan 1, 2008 12:56 PM
boggle
Dec 31, 2007 03:28 PM
otem
May 16, 2004 12:10 AM
