Scrapyard alternator...
Old Jul 14, 2013 | 12:27 AM
chillman88's Avatar
chillman88
Hey all,
I scoured the scrapyard today for an alternator for my truck and finally found one that I thought might work, except it tests as DOA.
The manager of the parts store identified it as a 7072. It is a 70amp and has a "T" shaped connector, an output, and a ground. Is this unit an externally regulated one? It came off an late 80's or early 90's f350 with a diesel, don't know the exact year.
I'm in need of an internally regulated one. Will the ones off the bronco-II's work? they looked like they might be the same as what I need. It's going in an 86 f150 with a 351w.
If it's worth rebuilding I might look into that, if not I've at least got a v-belt pulley I can use now!
Old Jul 14, 2013 | 01:04 AM
joshofalltrades's Avatar
joshofalltrades
i would suggest you put a 3g on there from a mid-90s taurus with the 3.0. its a 130a monster that bolts right up, just needs simple wiring and a pulley swap to make it work.
or if you want an exact fit, go to a parts store website like oreillyauto.com enter your vehicle, find your alternator, click on the tab that says compatibility, and you'll see a list of every vehicle your alternator was found in. i do this frequently when i'm searching for JY parts.
FWIW, the 86 would have come with the "flaming ford" alternator wiring, the one whose output wiring goes through a couple of blade connectors instead of a stud with a nut. they earned that name for a reason, thats part of why i suggested the 3g upgrade
joshofalltrades
double post
Old Jul 14, 2013 | 06:45 AM
Franklin2's Avatar
Franklin2
The diesels usually were externally regulated. I got rid of my "flaming Ford" alternator on my 86 Ranger and installed a alternator off a 86 monte carlo. I had to drill one of the holes out and re-make the bracket, but it works, and is internally regulated, and only has two wires going to it.
Old Jul 14, 2013 | 08:19 AM
chillman88's Avatar
chillman88
Yea I was thinking about getting the 3g but didn't know what vehicles they came in, and when I bought the truck there was no alternator so I didn't have a pulley to use. I've actually got a couple GM alternators but I'm not sure I want to commit sacrilege and make people mad haha. I'm just too cheap to go pay the $140 that the auto parts store wants for a new internally regulated 2g like mine had originally. Maybe I'll swap the pulley for the one on my GM alternator and take it back to the scrapyard for a taurus 3g, but then I have to wait until next saturday before I have time to make it back to the scrapyard!
Old Jul 14, 2013 | 01:20 PM
Franklin2's Avatar
Franklin2
That's why I did it also, i had it laying around. It was the little bit larger style GM(100amp) with a serpentine pulley, but the Ford pulley from the 2g slipped right on with a small spacer behind it. A regular GM with a smaller case may have fit even better. I am like you, the Ford alternator from the parts store is way too expensive. If the GM ever goes bad I believe I can get it for $40 or so rebuilt.
Old Jul 14, 2013 | 05:31 PM
chillman88's Avatar
chillman88
Yea I can get a cheapie GM reman for $30 at advance. I'm really leaning towards trying the pulley on my GM one, if it works i'll be golden, if not I'll probably head for the Taurus section at the scrapyard!
BigBlocker0248
Jun 4, 2016 02:42 PM
86f250XLT-4x4
Apr 11, 2013 09:27 PM
Tomboy
Dec 9, 2012 04:49 PM
1960 F100
Aug 28, 2007 09:54 PM
yoda
Oct 6, 2003 08:55 PM
