1979 wiring question
Old Jul 13, 2013 | 11:34 PM
1979 300i6's Avatar
1979 300i6
I found a 3 point "pig tail" with noting plugged into it with a black and green wire leading to it, under the dash by the steering Column, any ideas?
Old Jul 14, 2013 | 08:27 AM
teds74ford's Avatar
teds74ford
This?
If so, it is for keyed power.
Old Jul 14, 2013 | 10:40 AM
1979 300i6's Avatar
1979 300i6
That's what it is, whats it Designed too do?
Old Jul 14, 2013 | 11:16 AM
Filthy Beast's Avatar
Filthy Beast
It just sits there...waiting...... for a keyed accessory to be added. There's another one, just like it but green in color, by the heater control/glove box area. That one could be used for the ballast resistor wire replacement - so reads the Ford shop manual.
Old Jul 14, 2013 | 04:12 PM
1979 300i6's Avatar
1979 300i6
Anyone know about how the cig lighter hooks up? I read in my Haynes shop manual its a yellow and green wire which I have found, but this wire connects to 2 solid brown wires and the manual does not Mention this, and the wire is not getting any juice any thoughts?
Old Jul 14, 2013 | 04:34 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Go here:
http://fordification.net/tech/images...aster_8of9.jpg
Don't know if this will help but it's the factory wiring diagram.
The cigarette lighter is in position F4.
Old Jul 15, 2013 | 07:14 AM
fmc400's Avatar
fmc400
MSEE
BROWN is the running light circuit and has nothing to do with the cigarette lighter. The cigarette lighter plugs into the hot-at-all-times tap hanging behind the glove box (GREEN with YELLOW stripe).
Old Jul 15, 2013 | 05:32 PM
teds74ford's Avatar
teds74ford
This:
Is constant hot.
For clarification, the previous one was keyed hot, this picture is for constant hot. It is behind the glove box and is for the cigarette lighter. If you do a stereo, these 2 are really easy places to start for most of your wiring.
Old Jul 15, 2013 | 10:37 PM
mountainsportsman's Avatar
mountainsportsman
I've got another thread going, but I'm at my wits end. Where does the always hot connector for the cig lighter get it's power? More details here:
https://www.ford-trucks.com/forums/1...-question.html
Sorry and thank you!
Old Jul 15, 2013 | 10:46 PM
fmc400's Avatar
fmc400
MSEE
Courtesy lamp fuse.
psychlopath
Electrical Systems/Wiring
Dec 28, 2013 09:16 PM
WVU
Oct 12, 2011 09:13 AM
Highboy74
May 20, 2011 10:09 PM
txfour
May 20, 2009 06:56 PM
irondragon79
Jan 14, 2006 05:55 PM
