2 wire color questions, real quick
GREEN with a YELLOW stripe is hot-at-all-times power to the courtesy lights. There should be a tap behind the glove box.
There should be a BLACK with a GREEN stripe tap on the driver side behind the dash. However this is not fused. You can also borrow off the radio power (YELLOW with a BLACK stripe) which is fused.
hasteranger
07-15-2012 12:50 PM
