Starter issue
Old Jul 13, 2013 | 08:39 AM
materi's Avatar
materi
Starter issue
I am running a '83 302 is my 53 and i want to test fire it before i proceed any further in my project. I am having issue with it getting to turn over. I have a brand new battery/relay/#2 cables/starter. I have every ground to bare steel. I am grounded from the battery to the running board support. Then up front from the frame to the front of the engine. I have positive cable from battery to relay in post then from relay outpost to starter. The relay is mounted on the same bolt as the ground cable. I run a #10 wire from the battery to a switch to tje s post on relay and all i get is CLICK. CLICK. Even when i jump it with a wrench between the two big posts all i get is a few sparks. I have aleady removed the starter and had it tested and it passed with flying colors. Kinda looked like an idiot at the parts store walking in with a brand new starter asking to get it tested. I usually like solving stuff on my own but after 3 evenings and cant figure it out i am at witts end. Am i missing something? My starter is a one post and i have tried both 3 post and 4 post relays.
Old Jul 13, 2013 | 08:50 AM
The Horvaths's Avatar
The Horvaths
It's easy to locate the problem area(s). I hope that you have a Volt meter. If not, you deserve to own one. Do a search on the Internet for "starter voltage drop test" and all will be revealed. I like one called "starter voltage drop test explained in plain English" but there are many good web pages and videos out there. Good luck and please let us know what you find.
Note: also, check to see if the battery voltage itself drops significantly during starting. The internal resistance of a battery should not ever drop more than a couple of volts or so.
Old Jul 13, 2013 | 09:52 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The ground cable needs to go directly to the engine. Nothing connected to the frame draws more than maybe 10 amps. The starter draws 200+. That may not be your problem, but it won't help.
Old Jul 13, 2013 | 11:23 AM
Kurt G.'s Avatar
Kurt G.
I know you replaced everything but, you said test fire the motor. Is the motor rebuilt or one you bought/acquired I mean does motor turn freely. I do agree with the voltage drop test. The clicking sounds like bad selonoid. I have seen out of box bad units.
Old Jul 13, 2013 | 11:44 AM
materi's Avatar
materi
The motor is one i acquired with very low kilometers. I will try the above suggestions when i get home. Whats the difference between the 3 post and 4 post solenoid
Old Jul 15, 2013 | 11:36 PM
materi's Avatar
materi
Its alive!!!! I needed to ground on the starter housing not the frame. Thanks guys
Old Jul 16, 2013 | 05:48 AM
The Horvaths
Hip hip..
..Hurrah!
Old Jul 16, 2013 | 04:46 PM
Kurt G.'s Avatar
Kurt G.
Good job I'm glad it was that easy.
JordanL79
Jan 17, 2017 12:44 PM
frame30
13
Oct 9, 2012 11:21 AM
cdorroh
16
Sep 9, 2007 03:19 PM
S.N.A.F.U
Electrical Systems/Wiring
Aug 12, 2005 02:47 PM
rrisner
Apr 17, 2002 02:09 AM
