Need help 02 7.3
Old Jul 13, 2013 | 12:42 AM
timelines's Avatar
timelines
Need help 02 7.3
Hey guys i just got an 02 7.3, it takes a few cranks to fire up, seems to idle just fine, on revs it sounds like a knock in the bottom end left side, ive searched the forums/net ect but im leaning toward rod/main bearing maybe rist pin? it dont get any louder the more you rev i keeps its pattern. Also its dumping oil i beleive from under the turbo. Question where do i get the o rings from is it ford only? its got a fuel leak left side (fuel pump?) its in the frame rail? Anybody close to me that knows these trucks care to come take a look i know nothing about the psd as i have been a gasser up until a few days ago. I have always worked on my on cars/trucks but feel lost with this one . Im in Ozark mo.
thanks
Old Jul 13, 2013 | 05:19 AM
Tugly's Avatar
Tugly
"Few cranks to fire up" - the signature of tired injectors or injector O-rings. How many miles? Fuel pump is under your butt, on the frame rail.
Old Jul 13, 2013 | 09:16 AM
snakedoc's Avatar
snakedoc
bob has all of the orings and even upgraded ones. DieselOrings
how old is the oil?
it may be a loss injector making the knock or a bad one.
i worked on one that the injector was 90% dead and knocked like the piston was loss, new injector better starts and no knock.
Old Jul 13, 2013 | 10:21 AM
timelines's Avatar
timelines
Its got 302k miles, it seems to run good i know when you mash it she rolls the black smoke. its an auction truck and i didnt give much for it, i think some kid owned it theres alot of kobbled up crap cut wires ect. As for fuel leak it is the fuel pump (under butt) thanks for the replies guys like i said first psd ive got alot to learn.
Old Jul 13, 2013 | 10:34 AM
timelines's Avatar
timelines
As for o rings local parts stores dont carry them?
Old Jul 13, 2013 | 10:50 AM
woodnthings's Avatar
woodnthings
You can get them from the parts stores, just usually cost more and quite often they order them in. Ford will have them too if you have a dealer near you. Get Alliant o-rings if you can. They are proven and you won't have any issues.
Old Jul 13, 2013 | 01:09 PM
timelines's Avatar
timelines
Thanks for the reply Ken, i do have a dealer close by.
Old Jul 13, 2013 | 01:33 PM
sand_fiend's Avatar
sand_fiend
So, you bought it from an auction. blowing black smoke could be a performance chip or tuner. either of those will also make the diesel knocking sound more prominent. The o-rings are not all that hard to replace. it just takes time with the room you have to work with.
best bet would be to find A member around your area to stop by and have a listen to it before you start throwing money at it..
Old Jul 13, 2013 | 02:31 PM
timelines's Avatar
timelines
Ive asked in the mo thread for any local help, id pay for their time. Its got i believe 5in exhaust no cat or muffler, the turbo looks pretty clean for what the rest of the engine looks like. Yea auction truck 4 door 2 wheel drive, gave 2500 for it.
Old Jul 13, 2013 | 02:44 PM
sand_fiend's Avatar
sand_fiend
Nice.. that's great. so even if you have to put some money in to it, you'll be ahead..
if it has an exhaust im sure there is more done to it. is there aftermarket gauges in the truck ?. let us know if the stock air box has been changed. we can start from there and work with you..
Old Jul 14, 2013 | 10:57 AM
timelines's Avatar
timelines
No gauges, theres a small vacuum line under the dash it goes up to a t ontop of the engine looks like it goes go ghe turbo maybe a boost gauge line? Stock air box i believe. I had to go out of town when i get back ill get some pics. These came factor garret turbo right?
Old Jul 14, 2013 | 11:19 AM
guitarpicr's Avatar
guitarpicr
Yes -Garrett is stock turbo
Old Jul 14, 2013 | 11:35 AM
timelines's Avatar
timelines
Ok i had read that. Its really clean so id say its been off recently, replaced, rebuilt somthing.
Old Jul 17, 2013 | 07:32 AM
Moe power stroker's Avatar
Moe power stroker
Hopefully its injector issues, it wouldn't hurt to get a compression test done just to make sure all the pistons, rings and valves are good. I had a 7.3 once that had some problems and it turned out from the compression test number 5 cylinder was a dead hole with no compression, I never even tore that engine down just replaced it with a low mileage engine from a wrecked truck that has ran perfect for over 7 years. Never tried any tuning left it stock.
Old Jul 26, 2013 | 02:29 AM
Tinkerbell73's Avatar
Tinkerbell73
If you're leaking oil, check your oil level in your high pressure oil pump. I had this issue a while back. :-)
dylanyonkovic
22
Aug 24, 2023 09:32 AM
Crazywesc
Sep 20, 2016 08:31 PM
regidog
Jan 15, 2011 06:29 PM
scatgo
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Jan 17, 2008 12:55 PM
lifted_01_SD
22
Jun 25, 2006 07:11 AM
