Modular V10 (6.8l)
Is my MPG normal?
Old Jul 11, 2013 | 11:30 PM
jerem0621's Avatar
jerem0621
Is my MPG normal?
My 99 V10 2wd Crew Cab Dually gets 9-10 mpg empty.
Thats me driving around at 60-65 mpg on the interstate, keeping the RPM's under 2000 as best I can.
I have 3.73 rear axle ratio
running 235/85r16
Cost me about 75$ to run 200 ish miles.
The sticker on the door says that I should be running 215/85R16's, I am not sure if that makes a difference or not.
Oh, I have new cop's, new plugs, new fuel filter. Truck runs like a champ except its a pig on fuel.
13 mpg would simply make my day!
Jerem
Old Jul 12, 2013 | 12:22 AM
twigsV10's Avatar
twigsV10
A 215 tire is smaller than a 235 and if the speedometer hasn't been corrected for that you will be going faster and farther than the odometer says, and that will make your mpg lower than it really is.
Old Jul 12, 2013 | 07:30 AM
projectSHO89's Avatar
projectSHO89
Quick reality check for V10 owners: Does your fuel economy suck? If yes, then it's normal.
Fer crissakes, its a 6.8L V-10 hauling around a CrewCab Dually! It's supposed to gulp fuel like it owns a refinery.
Old Jul 12, 2013 | 07:58 AM
bcshaunr's Avatar
bcshaunr
...isnt that the width and would have no effect on the speedo..?
Old Jul 12, 2013 | 08:41 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Head down to Autozone and pick up 2 bottles of Chevrons Techron additive, fill up and run the truck. This additive really cleans things up and works wonders on whatever gas engine I've used it on.
It's also one of the things you do to Cristen your V10.
Old Jul 12, 2013 | 09:04 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
215/85/16 are 30.4 dia and 235/85/16 are 31.7 dia so it does make a difference in both the speedometer and power.
Denny
Old Jul 12, 2013 | 10:17 AM
jerem0621's Avatar
jerem0621
Yea, I drive 70 miles per day on average. Any extra mpg I can squeeze out of it helps immensely. I don't need a reality check. I've owned this truck for a long time. Just wanted to make sure it was normal.
Sorry if it offended anyone for asking a question.
Old Jul 12, 2013 | 11:19 AM
mudfuel06's Avatar
mudfuel06
Sounds about normal for what you have. Use a GPS to get your corrected mpg.
Old Jul 12, 2013 | 03:11 PM
zoenemo1's Avatar
zoenemo1
I was wondering the samething I have 2001 f250 4x4 with 35's and 4.30 gears this seems to get 9 mpg city.I think my gas gauge is of because went to fill up,fuel light just came on and I could only get 21 gallons in the tank.
Old Jul 12, 2013 | 03:51 PM
scozim's Avatar
scozim
Agreed. I've got a 2001 E350 15 passenger (brick wall through the wind) and on a 2400+ mile trip in March averaged 13.5 mpg hauling 8 of us and all our stuff. I was actually surprised with that considering some of the wind we went through. Empty driving it home from New Mexico when I bought it the thing averaged 16.5 but I kept it at 60 mph almost the entire time. Hauling my RV trailer last weekend - that was a whole different ballgame at between 7-8 mpg
They're supposed to be thirsty.
Old Jul 12, 2013 | 11:15 PM
jerem0621's Avatar
jerem0621
Tires are due on the beast so I am going to go back to 215/85's, get an alignment.
I'm thinking about changing to full synthetic fluids in the Motor, Transmission, and rear end. I'm thinking about adding a Sonnexx Tricumulator kit to the 4r100 transmission, and changing fluid out to synthetic (Amsoil?), Rear end was serviced, I am not really sure when, so I think I am going to swap that to synthetic as well. I have an open diff so no friction modifier needed. LOL
Not sure if that will help MPG's but I will sure feel better with all of this added to my truck.
Thanks for all the comments, I really appreciate it.
Jeremiah
Old Jul 13, 2013 | 12:31 AM
twigsV10's Avatar
twigsV10
3.73 gears are not the best for the 2v v10 as it likes to rev, smaller tires will help. The v10s sweet spot seams to be at 2100rpm but with 3.73s that's going to fast to help with mpg. Lastly I don't think you offended any one there are a lot of people that have gone from a car to a big truck on hear and are shocked they don't get 25mpg lol, there are also the v10 haters (mostly diesel owners lol).
Old Jul 13, 2013 | 09:49 AM
rvpuller's Avatar
rvpuller
Jeremiah
The rear end should ready have synthetic in it if the right fluid was used when it was changed.
Denny
Old Jul 14, 2013 | 08:48 PM
Sven the elder's Avatar
Sven the elder
I knew it before I got it.(checked out the site here.) I'm glad I got it,gobs of power when pulling the trailer. Also glad I only have to drive 10 miles round trip to work each day.
Old Jul 16, 2013 | 07:37 PM
jakgod3's Avatar
jakgod3
I get about 13.4 average city/highway with my F250 Crew Cab, SB, SRW, 3.73.LS. If I set the cruise at about 65 I can pull about 14.2 and 14 at 60. The best I have found in my truck is around 2100-2300 rpm in OD. When I run on the freeway I set the cruise at 82 and believe it or not I have pulled about 16.7 avg mpg on a long trip (hand calculated). My Lie-O-Meter seems to be pretty consistent and is only about .2-.4 mpg off. Also i'm running 275/75r16's.
