Hey guys, anyone know where to find temp gauge for a '66? Tried the usual places without any luck. Replaced sending unit, still not moving, any ideas?
Thanks
Is it the larger gage located to the right of the speedo as in the custom cab instrument cluster or one of the small gages located around the perimeter of the speedo?
Thanks
Asking the obvious... is it hooked up on the back of the instrument panel to both the sender and the power supply .... Constant Voltage Regulator?
8 or so screws and you will know.
By the way.... if you replace.... buy a permanent replacement... why buy a temp?
