Bad Fuel
Old Jul 9, 2013 | 07:24 PM
75dually's Avatar
75dually
Bad Fuel
Posted this in the wrong place earlier doh
I did something I've never done before, bought cheap diesel of a bloke down the street for my 7.3 IDI, almost immediately the truck started running rough, misfiring, hardly any power, top speed 15mph, drained the tank and lines, fitted new filter, filled up with fresh fuel but still running the same
Old Jul 9, 2013 | 07:41 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
it was diesel right?
could try another new filter on there and fill the filter with ATF, start and run engine for a few seconds then shut down and let sit over night.
Old Jul 11, 2013 | 12:00 AM
75dually's Avatar
75dually
It was supposed to be Diesel, now i've drained it out it doesn't smell right
Old Jul 11, 2013 | 04:33 AM
ihateminimumwage's Avatar
ihateminimumwage
Run a generic inline filter where the fuel line goes to (or is supposed to go to) the water separator on the drivers' side fender. If the fuel is just dirty you'll be able so see what is building up.
Fill your tank up and run it, even if it was gas, such a small percentage won't affect it.
We end up with some free fuel through work changing filters, and I messed up and didn't filter almost a gallon through a rag (just to catch the big stuff). Within a week my inline filter was so clogged with sludge, sand and who knows what the element was collapsing and the truck would die every time I'd hit a stop sign. Changed the filter, filled the tank, tossed in some diesel kleen and a couple quarts of ATF and just keep track of it now. No issues at all (I keep a spare filter with me though).
Old Jul 15, 2013 | 06:00 PM
75dually's Avatar
75dually
Tanks clean, lines clean, new filter, fresh fuel, **** loads of injector cleaner in new fuel truck will barley do 30 mph on the flat, no power at all. Where's best/cheapest place to get an Injector Pump? not many places will ship to the UK
Old Jul 16, 2013 | 02:13 AM
ihateminimumwage
Not many places have good ones in the US either, hope someone can chime in and help.
I've heard of people soaking the entire pump in a bucket of PB Blaster for a couple of days to get everything cleaned out. Haven't tried it myself though.
Old Jul 22, 2013 | 06:27 AM
75dually's Avatar
75dually
Just had a call from the shop, he says it looks like someone took a **** in my injector pump same with the injectors, looks like it just needs a good clean out then
Danner23
Jul 21, 2013 07:44 PM
jr-idi
Apr 9, 2013 02:17 PM
linus72
15
May 6, 2012 03:53 PM
av8tor09
Feb 21, 2009 09:48 PM
jmmartin
24
Dec 27, 2007 08:20 PM
