Yet Another 100% thread
[IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMGNow I don't know of any problems currently, but I will be driving it about 5 hours home so will see if anything arises during that time.
First thing I plan on doing is all the fluid changes (besides oil since its getting changed as I type this)
I am planning on doing a change over to an ELC if I can find any around here. Where do people get their Distilled water? I feel kinda odd going to Walmart and loading up 2 baskets of water if the 30-40 gallon approx is accurate.
Searching for ATF change but everytime I search it comes up with 11 pages of info that I haven't gotten through yet so if anyone has a quick link I would appreciate it.
Since the oil is getting changed, I won't worry about that now.
Will be hitting all the zerks with grease as well.
Any fluids I am missing? I don't know enough to do a rear diff fluid but I will try to read up on that as well.
So once the fluids are changed out, what should I look for next? Everything I read seems to point to gauges/reader. I got into search overkill for this topic as it seems (rightly so) everyone has their favorite setup. If people could give some of their pros and cons for their setup (as unbiased as possible) I would appreciate it. Right now I like mechanical gauges so I have something consistent to look at but I don't know if I should just save up and go for the Infinity package since it has scanning ability as well as tuning and it seems like a little of everything else thrown in or if I would be better off doing a setup with a couple gauges and a scanner gauge like an Interceptor gauge from Aeroforce Tech with a ScangaugeII then when the time comes going with a DP6 or hydra chip. I'm not currently planning on going crazy but who knows what the future holds. This is something I never really have gotten into with my other vehicles so its new territory.
I do want to get a fuel pressure gauge asap and make sure the fuel system is functioning properly and probably a 6637 filter install. I will be building a boost leak detector and checking for that as well.
What would be the most beneficial maintenance-style mods to do to get the truck functioning properly?
I don't know if the truck has had any transmission work done to it, what would I be looking for if it has?
I know there are a ton of these trucks running around without people worrying about all this stuff and they are doing just fine but I want something I will be comfortable with knowing the maintenance has been performed properly.
Thanks for the help I have already gotten from the site on other threads I have had and looking forward to being here for awhile and hopefully being able to help others in the future.
Welcome to guzzle's Front Caliper Slide Pin Upgrade Web
Needle bearing link
Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
Auto/lock hub link
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Needle bearing link
Auto/lock hub link
The one that drops down by the headlight is an add-on for something that's non-stock, I believe.
Pop
Pop
So I have those coolants nearby for when I get the truck home. I'm reading up on the grease jobs.
Any other comments on some of the other topics? I'm always open to thoughts and ideas.
Seems like a straight shooter, hope the truck serves you well.
Keep reading and you don't have to take care of everything the first weekend. LOL
Other than that the truck runs great! I will have some questions a little later, I think the truck is stock but there are a couple things I dont remember seeing. The interior is a little rough and will need a new rear bumper. I have a lead on the bumper but does anyone know of an inexpensive place that does 40-20-40 seat covers?
