swap 400m to 429 problems
Old Jul 8, 2013 | 10:12 PM
DavidSmealII's Avatar
DavidSmealII
alright. i have almost everything...got the motor in and got all the stuff ready to roll to put the c6 tranny up on the 1970 429 motor....the transmission wouldn't draw up. after a while we realized the snout for the torque converter was wasn't going into the end of the crank...so in this matter i really need a straightforward answer.
can i put a car torque converter in the c6 even if its 4x4? not really sure if it would matter or not but just making sure so i don't spend more money than i have to...
or
is there an alternative. and i know its not a pilot bearing since its not copper
Old Jul 9, 2013 | 12:42 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Pilot bearing only used with M/T and they're not always made of bronze (copper too soft, wouldn't last a day). Some are sealed bearings that internally, have a dozen or so needle bearings.
Old Jul 9, 2013 | 01:02 PM
DavidSmealII
That still doesn't help me. I highly doubt a ltd had a four speed.
Old Jul 9, 2013 | 01:16 PM
NumberDummy
Originally Posted by DavidSmealII
That still doesn't help me. I highly doubt a LTD had a four speed.
Uh huh, take a look-see at A (Galaxie/LTD) 429 M/T application.
F/4/S = Ford 4 Speed, same trans installed in V8 Mustang/Cougar/Fairlane/Torino/Comet/Montego and etc.
Old Jul 9, 2013 | 02:41 PM
ranger429's Avatar
ranger429
or
Um sure it does. Like he stated a pilot bushing or bearing was only used with a stick so it isn't even relative to your situation.
As far as a 429 is concerned there were 3 different hub pilot dimensions for the end of the crank. I have no idea if there is a difference between a car/truck converter but if it were me I would order a new converter to eliminate the possibility of having to tear it apart again to replace.
Old Jul 9, 2013 | 03:01 PM
NumberDummy
No truck converter, cuz 429's were only installed in misc 1968/73 Ford/Merc passenger cars, 1968/71 Thunderchickens.
Old Jul 9, 2013 | 03:09 PM
ranger429's Avatar
ranger429
Correct, completely spaced that part.
So to answer the OP's question he must go with a car converter. When I did my swap I ordered a new TCI converter, I think it was right around 150. Mot worth using an old converter. Just check the pilot hub dimension.
Old Jul 9, 2013 | 05:27 PM
DavidSmealII
alright thanks! thats all i needed to know..ill just get a "LTD" converter...
Old Apr 9, 2022 | 08:41 PM
Incognito8P's Avatar
Incognito8P
Awe man... I wish I realized this sooner. 😂 Just spent most of the day trying to figure out why my new 429 wouldn't snug up to the c6 in the camper special. Guess I'll be out looking for a new converter
Old Apr 9, 2022 | 09:04 PM
tbear853's Avatar
tbear853
Gator McClusky drove a 429 4speed LTD.
Glad you found your answer though, car converter will do fine ... just "had to".
Old Apr 9, 2022 | 09:51 PM
440 sixpack's Avatar
440 sixpack
I converted to a 429 in 1988 and just used the car convertor. it's still working fine today.
Highboy74
Apr 19, 2012 04:08 PM
X19
Nov 18, 2003 12:23 AM
dozippy
21
Aug 20, 2003 03:14 PM
Ratsmoker
Aug 12, 2002 10:08 AM
BroncoSteve
May 9, 2002 12:20 PM
