Torque Converter Nose Will Not Seat Into Crankshaft. Why?
Old 04-18-2012, 07:35 PM
Highboy74's Avatar
Highboy74
Highboy74 is offline
Highboy74 is starting off with a positive reputation.
I bought a 1969 Ford 429 with a C65 and when I did the rebuild, I placed a 460 crank in it. Yesterday, I got back the C6 that was attached to the 429 after it was rebuilt. The transmission company who rebuilt the C6 had the original torque converter rebuilt to a 2200 stall to match my cam. Today, I went to try and put it all together, but the nose of the converter will not slide into the back of the crank. I made sure to get all the rust out of the back of the crank and all the paint from the nose of converter. Anybody have an idea of why it will not slid into the back of the crank?
Old 04-18-2012, 08:22 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Measure the diameter and depth of the pilot on the torque converter and the diameter and depth of the hole in the crankshaft flange, that will tell you where the problem is.
Any chance the 460 crank was manual trany and there is still the outer race of the pilot bearing in it?
Old 04-18-2012, 08:26 PM
tbear853's Avatar
tbear853
tbear853 is offline
tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.
Check for pilot bearing or bushing from previous life in the 460 crank.
Old 04-18-2012, 08:30 PM
Highboy74's Avatar
Highboy74
I checked to see if there was a bearing in there. There doesn't seem to be. I'm gonna need to find my gauges and measure it out. Just with a tape it seems to be a close fit.
Old 04-18-2012, 08:34 PM
thekingofcows's Avatar
thekingofcows
thekingofcows is offline
thekingofcows is gaining momentum as a positive member of FTE.
Early 460s cranks share the same crank pilot as the Fe motors, its in the 1.8" diameter range and is not as deep.
The later ones used a 1.375 crank pilot that was deeper
Old 04-18-2012, 08:59 PM
Highboy74's Avatar
Highboy74
So, if that is the case I'm assuming I need to have the converter nose machined down?
Old 04-19-2012, 01:15 AM
thekingofcows
No, the converter you have is probably the 1.375 snout, it won't work. you will have to buy a converter with the correct snout. I think any FE converter will work. I bought mine from BTE in Memphis TN, but you can get them anywhere, just don't settle for a sub par rebuilt converter, go on and get a good one.
Old 04-19-2012, 04:39 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
460 not available with a M/T until 1983. All 1968/82 460's came with the C6.
429's were available with a M/T in 1969/70 Mustang Boss 429, 1971 Mustang 429 CJ.
Old 04-19-2012, 08:47 AM
mark a.'s Avatar
mark a.
mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
I have a C6 B&M Traveler series T.C. that would fit your crank. It was only used for 20 miles then removed. There was nothing wrong with it or the trans it came from so it is clean inside. PM me if you want it for real cheep.
Old 04-19-2012, 02:49 PM
Highboy74's Avatar
Highboy74
This is what I'm dealing with. Now what?
<a href="http://s1178.photobucket.com/albums/x377/Highboy74/?action=view&amp;current=DSC07469.jpg" target="_blank"><img src="http://i1178.photobucket.com/albums/x377/Highboy74/DSC07469.jpg" border="0" alt="Photobucket"></a<a href="http://s1178.photobucket.com/albums/x377/Highboy74/?action=view&amp;current=DSC07468.jpg" target="_blank"><img src="http://i1178.photobucket.com/albums/x377/Highboy74/DSC07468.jpg" border="0" alt="Photobucket"></a>
Old 04-19-2012, 04:08 PM
OldStyle's Avatar
OldStyle
OldStyle is online now
Rusty Roller
OldStyle has a very good reputation on FTE.OldStyle has a very good reputation on FTE.OldStyle has a very good reputation on FTE.
Looks like a job for a machinist! Get the correct dimensions and have it professionally cut down the .027's or so. Find a quality shop and not just someone who happens to have a lathe.... It won't be the easiest thing to true up.
That or take Mark up on his offer.
Edlomax
New Member Introductions
09-19-2016 01:32 PM
Darn72
63
06-02-2016 06:26 PM
DavidSmealII
07-09-2013 05:27 PM
Highboy74
06-07-2012 11:55 PM
dcdave
02-16-2008 07:29 PM
Quick Reply: Torque Converter Nose Will Not Seat Into Crankshaft. Why?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
