AOD Problems, or is it speed sensor problems???
Old Jun 18, 2002 | 08:51 AM
John7894's Avatar
John7894
Guys,
I have a 1994 F-150 Supercab XL w/302 and an AOD. The speedo jumps every now and then, the ABS light is on (steady), and it shifts hard and seemingly quick, into second gear (always). Also, cruise control won't hold a steady speed (fluctuates up and down), and it comes out of gear pretty often (any gear, any speed, any time). Are all of these symptoms related? Could it be the speed sensor? The dealer told me that there is a sensor on the rearend and one on the tranny that could be causing this. The dealer also said that it could be the speedo in the dash. Any idea which one could be the culprit?
Also, I got a price on the above parts, all seem bearable except the speedo. One sensor was $13, and the other was around $45. Also, the dealer told me that I had to buy the whole instrument cluster, I couldn't buy just the speedo module. Also, this sounds weird, the price on the whole cluster w/o tach is around $350, but the price for the whole cluster w/tach is around $175. Does that sound correct? Can I buy the one with the tach and install it in my truck that does not have a tach. That would be a real nice upgrade.
I can do all of the work myself, I'm just not familiar with the new electronic speedos. This is the first problem I've ever had with my truck since I bought it used in 1996.
I appreciate any of your help.
John
Old Jun 18, 2002 | 02:52 PM
John7894's Avatar
John7894
TTT
Old Jun 19, 2002 | 07:08 AM
eakanator's Avatar
eakanator
Start with the sensor in the rearend, this will cause your speedo to start jumping and also make your ABS light stay on. very simple to change. pull the plug off, a 10mm socket, loosen the bolt that hold it in, pull it out and and install the new one. Drive and see what happens, I should that fix the majority of the problems. the Sensor is right middle and above the rearend.
Ron
Old Jun 19, 2002 | 09:16 AM
John7894's Avatar
John7894
Thanks Ron. I'm picking up the sensor on the way home, I'll keep everyone posted.
John
Old Jun 22, 2002 | 09:58 PM
John7894's Avatar
John7894
Sensor cured the ABS light right off of the bat, Will have to drive it to see if everything else works. Cruise appears to work OK too. I'll keep everyone posted.
John
Old Jun 24, 2002 | 03:44 PM
John7894's Avatar
John7894
Here's the lowdown!!! The sensor solved the ABS light problem. The speedo appears to stay still, NO JUMPING! But the tranny still comes out of gear every now and then.
Is this a speedo problem or a tranny problem?
I'm at the end of my rope.
John
Old Jun 25, 2002 | 10:20 AM
mu5tanggt's Avatar
mu5tanggt
Check the electrical connection to the trans, 2 on trans, 2 under master cylinder, fixed my 92 bronco.
Old Jun 29, 2002 | 09:39 AM
robromine's Avatar
robromine
:-X11 do what that guy just said then if that dosent work you have a dirty valve body or filter
Old Jul 3, 2002 | 11:05 PM
bufordt's Avatar
bufordt
If its an AOD, your detent cable is critical to the tranny, it runs your shift points and pressure. If this cable breaks, the transmission will usually cause alot of promblems in 3rd and 4th gear. Also I know on older fords with AODs the nylon bushing on the cable was proned to wearing out and causing promblems. Just something to check.
Old Jul 3, 2002 | 11:18 PM
MustangGT221's Avatar
MustangGT221
Just so you know, if you get a gauge cluster that is the same year as your truck, you can install it with a tach and it will work. If you get one from a dealer, they have to program it and everything, but you could do that too. The speedo jumping and cruise control problem are related. If you noticed, the cruise with fluctuate with the needle bouncing. The speedo is tapped into the system becuase the cruise needs to know how fast you are going. You can't use cruise under 30mph and it will shut off cruise if the speed drops 10? mph or something close to that. Just some info :-)
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Sunroof, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Then theres:
99' Mustang GT 4.6L
88' F-250 Superduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Top speed is 65mph, Go Baby Go!
Old Jul 14, 2002 | 07:12 PM
Paul_no's Avatar
Paul_no
Post AOD Problems, or is it speed sensor problems???
What is the "Detent cable"? I am having occasional similer probs on my 86 Bronco w/AOD and 5.0
Old Jul 14, 2002 | 07:48 PM
ka_88FORD's Avatar
ka_88FORD
Amish65F100
Apr 5, 2017 08:37 AM
Matt Joines
Electrical Systems/Wiring
Jan 7, 2017 01:55 PM
fordtrucksforever
Jun 26, 2016 03:02 PM
93nighthawk
Aerostar
39
Sep 23, 2015 08:55 PM
Special_edward
20
Jan 6, 2008 08:31 AM
