2000 F150 window problems
Old 07-08-2013, 12:57 PM
sandra 44's Avatar
sandra 44
sandra 44 is offline
I need some help and I can't afford mechanic prices, my passenger window won't go down from the drivers side button but will go up the passenger side button works is this hard to fix and my second question is the trip odometer fades in and out is that an easy fix also...thanks for any help given
p,s, I reckon I should mention I am 68 and a woman
Old 07-08-2013, 03:43 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
The switch in the driver side panel is easy to replace but does require basic tools and removal of the door panel.....a not uncommon problem.
The odometer- That I will leave for a tech....
Old 07-08-2013, 03:49 PM
sandra 44's Avatar
sandra 44
I think I can do that, now to find the part I need, oh is the panel hard to remove. Thanks for your help.
Old 07-08-2013, 05:55 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
Check on the crutchfield stereo website...they have great pics/instructions on how to remove door panels, etc. for your specific vehicle. Also Helm's (who sells oem service & repair manuals), allows online access to you your specific vehicles factory service manual.....IIRR it is like $10 or $20 for 1 day access.
Old 07-14-2013, 06:39 PM
Switch Doctor's Avatar
Switch Doctor
Switch Doctor is offline
Window Switch Installation
Its pretty easy to remove the switch, I have some installation guides here that will help you http://www.switchdoctor.net/removal-installation Best priced switches as well http://www.switchdoctor.net/ford-f-1...ow-switch.html
Old 07-14-2013, 07:40 PM
Hookster's Avatar
Hookster
Hookster is offline
You just reference the trip odometer, is the the odometer that fades in and out? Just doing a search on odometer fis should give you the solution. It does require basic soldering skills.
Kwikkordead
31
01-05-2017 08:15 AM
troyrhomeo
1997-2006 Expedition & Navigator
09-01-2008 04:40 PM
thebenchman
2004 - 2008 F150
07-11-2008 11:17 AM
f250mtnbikr
1999 to 2016 Super Duty
02-04-2004 05:43 AM
SirDino
05-31-2003 02:42 PM
Quick Reply: 2000 F150 window problems
