Highboy bed swap - bent frame?
Old Jul 8, 2013 | 10:23 AM
77-HiBoy's Avatar
77-HiBoy
I have an early '77 highboy that had a junk 2wd bed on it. I found and am in the middle of mounting another 2wd bed and have discovered that the new bed requires 11/16" spacing under the rearmost mounting bolt/support in order for the truck lines to match with the cab. This is not the small bracket between the last two bolts, but the last bolt support.
The former 2wd bed on my highboy did not have the small bracket re-sized between the last two supports, due to some shiesty work by the previous owner.
I am looking for input from others that have swapped 2wd beds onto highboy frames. Is it expect to have to shim the rear of the bed to have it align with the cab and front of the truck?
It is probably worth noting a few things about the truck.
  1. I entered into a local sled pull event and was categorized with the big boys (>8,000 lbs) due to the 24v cummins I am running, so I was pulling a lot of weight.
  2. I installed 3/16" plates over the rear axle u-bolts to limit the suspension travel. The plates faced inward and underneath the frame. These bent during the two pulls. Imagine this as a leverage point on the frame during the pull.
If it is not common to have to shim the rear of the bed, then I am wondering if I bent the frame behind the axle. What do you think?
Old Jul 8, 2013 | 01:00 PM
hickory1991's Avatar
hickory1991
I am putting a 73 2wd bed on my 76 highboy and welded in a 3/4 thick block of steel to match the highboy bed rear mounts. Just drilled holes for bed bolts to go thru. One cross member on bottom of bed was also different location than the highboy bed.
Old Aug 17, 2013 | 04:25 PM
77-HiBoy's Avatar
77-HiBoy
Hickory1991, thanks for the validation. I am using the bed from a 79 2wd. I ended up shimming every mount point, with the rear shimmed the most. The front is shimmed 3/16 and everything aligns perfectly.
Narwhal
35
Jun 26, 2020 07:34 PM
fyreduck1921
Aug 6, 2013 07:08 PM
grinnergetter
Nov 11, 2011 06:07 PM
79babyblue
Jan 16, 2007 11:52 AM
65F100project
Aug 22, 2006 06:12 PM
