squeeling clutch!!!!
Old Jul 7, 2013 | 11:08 PM
flip63's Avatar
flip63
I have a 79 f250 crew 4x4. I noticed the other day a very ugly squeeling noise while on the highway. It only happens after driving it for about 20 minutes. Is my clutch going out? 460 with a borg warner 4spd.
thanks
Old Jul 7, 2013 | 11:54 PM
brian1080's Avatar
brian1080
You don't give much info, does it sound like it's from the engine bay or under your seat? Squealing could be:
Belts
Brakes
Clutch
TOB
ALT
PS Pump
to name a few
Old Jul 7, 2013 | 11:57 PM
dw_wanno's Avatar
dw_wanno
Does the squeal change when you push in the clutch?? If it does then it could be a dry throw out bearing, which would mean the same thing (labor wise) as replacing a clutch.
If it doesn't change noise, then describe where the noise sounds like it is coming from, and any thing or condition that causes the change of the squealing noise (i.e. acceleration, decel, light braking, hard braking, up shifting, down shifting, etc.).
flip63's Avatar
flip63
its definitly the clutch area. Now its happening when the clutch is engaged or not engaged. Its more like a rattling maybe. I noticed the bellhousing is cracked by the clutch fork area too.
Old Jul 8, 2013 | 12:00 AM
flip63's Avatar
flip63
i dont mean to sound like a tard but thye best way to describe the sound is like two pieces of thin metal almost rubbing eachother.
Old Jul 8, 2013 | 12:25 AM
dw_wanno's Avatar
dw_wanno
Have you checked the amount of gear oil in the trans? Also is the noise only happening when going down the road? A dry throw out bearing can squeal on you whether you are moving or not. If it's only doing it when driving, then take it into a reputable shop (one that has experience with transmissions) and let them listen/ check for possible bad input shaft bearing.
Regardless, if your bell housing is cracked, then I would start preparing for a transmission pull after checking for bad bearing first.
Old Jul 8, 2013 | 05:48 PM
Boodrow379's Avatar
Boodrow379
thanks
Mine was doing the same thing.. tighten your clutch a few turns and see what happens
Old Jul 8, 2013 | 09:04 PM
flip63's Avatar
flip63
checked the trans today. Very little if any gear oil!
Aj Cook
Nov 8, 2017 09:03 AM
cjcathey2002
Apr 23, 2008 12:09 PM
bcsbadboys
18
Oct 13, 2007 10:17 PM
Texas Outlaw
Nov 13, 2006 04:43 PM
skipper
1978 - 1996 Big Bronco
Jun 26, 2001 03:57 PM
