does any one know if there is a difference in the turn signal switches between the 2wd and 4wd 66 ford trucks have one from a 4wd and the brake lights nor the flashers work and not sure why
C2TZ-13341-D (replaced C1TF-13341-D, J & K) .. T/S Switch / ID number marked on paper label looped over wires: C1TF-13341-GorC1TF-13341-KorC2TA-13341-D / Obsolete
1961/65 F100/250 4WD / 1961/66 F350/1100 (except F700/1100 Tractor Trailer) / 1966 F250 4WD
---------------------------------------------------------------------------------------------------------------- C9TZ-13341-C (replaced C5TZ-13341-A & B) .. T/S Switch / ID number marked on paper label looped over wires: C5TA-13341-BorC9TA-13341-A / Obsolete ~ Carpenter has 388.
1965/66 F100/250 2WD / 1966 F100 4WD / 1967/68 F100/350 / 1969 F100/350 before serial number G30,001.
With 4 way emergency flashers, there are two flashers (13350) behind the dash. One for the turn signals, t'other for the 4 way flashers.
its being a real pain I put the old switch and everything works the only thing I can think of is the wires go on the top of the cam and the original one the wires go under and inside
